Dome Light On with Door Open
I admit to being lazy as this is in the manual, but when I need the light, it's dark outside. Which switch goes in what position to enable the dome light to come on when the driver door is opened?
JimB
P.S. - 2014 ES350
JimB
P.S. - 2014 ES350
prob would have taken less time to look it up than to post about it.
Well try opening the door, changing the light switch, and then repeat until you find the correct position. If this is too complicated try reading the owner's manual...
You can download a pdf of the owners manual from:
http://drivers.lexus.com/lexusdriver...nual-search.do
I find it is quicker to search an pdf than it is find things in the paper book.
For the record I did try to look it up in the manual once, looked on the cabin diagrams for the light and switches. Most of the other items had a page call out shown, but the dome light and switches had an asterisk that denoted "check the owner's manual".
