How much does power seat drain the battery?
Hi, I have a quick question:
Do I need to concern much about the automatic driver seat movement with the "easy exit" on? How much impact could it have on the battery life? Thanks!
I agree, do not even think about it.
While I doubt that the automatic movement of the seat is using enough battery power to cause a problem, I find the automatic movement of both the seat and the steering wheel to be a nuisance. In particular, I find it annoying to have to wait the few seconds for them to finish moving, and I have the movement of both of them disabled. The seat movement can be disabled through one of the personalized settings that can be done by the user. The steering wheel movement can be disabled via one of the personalized settings that is "dealer only", but it can also be changed by the user by using either the Carista smart phone app or the TechStream software installed on a laptop.
While I'm sure that having the seat and steering wheel move automatically can be a nice feature for someone who is somewhat overweight or who is mobility-limited, for an average-sized person, I'm not sure that I see value in having them move. Also, while I'm guessing that the motors that move the seat and the steering wheel are designed to keep working through a very large number of uses, I'd also guess that those motors can eventually fail, and, for me, I see little point in having them operate unnecessarily if I don't really need to have the seat or steering wheel move to be able to comfortably enter and exit the car.
My seat doesn't move, but I drive with it all the way back. Only my wheel moves, which is a great.
I would not let the kids play with moving it back and forth. I would expect that it would stop moving (and the kids would get bored) within an hour or two.
For modest amounts of use -- I agree with Arty. Don't worry about it. Moving the seat to vacuum under it isn't going to drain your battery.
I would be more concerned about the automatic headlights staying on for 15 or 30 seconds, than the seat motor running for 2 or 3 seconds. Hopefully the Lexus design engineers know what they are doing to prevent draining the battery in the coldest weather.
I happen to like the feature of the seat moving back and wheel forward, an no I am not overweight or mobility challenged....but some day I may be !
If you find them to be true conveniences, by all means, use them, but, for me, I'm glad that there is the option to disable the movement of the steering wheel and the seat.
AllenK
ES - 5th Gen (2007-2012)
10-16-17 09:57 AM
