Micro SD card not reading
The internal memory on my audio player works fine thru the USB port in my 2013 ES-350. The problem is the micro sd card for the player. I've tried everything but it won't read. I've tried 3 different SD cards and used SD formatter to format the card (full erase and FAT32 format). The card works fine with thru the player and my home PC. Has anyone experienced this problem? I've given up...
What player and what file format?
fwiw, the car recognizes wma mp3 and aac files from a flash drive.
I am not sure you can do what you are trying to do.
I have a 2015 (which has a newer audio system) and this is what it says in my manual:
Not sure if it applies to your 2013 or not but it looks like it was not made to be used that way.
"Map data for the navigation system is
contained in a SD card that is inserted in
the SD card slot located at the bottom of
the audio control panel.
Do not eject the SD card, as doing so
may deactivate the navigation system."
waddoguy
ES - 5th Gen (2007-2012)
05-29-22 01:06 PM
waddoguy
01-23-13 08:53 AM
