ES350 Cargo Net Issue
Howdy,
Just purchased a new 2015 and it came with the cargo net option. The net stores in a bag that is anchored to the rear trunk wall. When I try to access the spare tire I can't lift the floor panel that covers the well. The cargo bag overlaps the solid floor panel and won't let it lift. I tried removing the net from the bag to make the bag more flexible but it still blocks any attempt to lift the trunk floor panel.
There must be a way to do this and I'm just too dumb to see it right now. I was able to finally lift the panel with a combination of tucking, twisting, and cursing my way through it. Surely I'm overlooking something obvious?
If the cargo net bag would just unclip then the problem would be solved. But it appears to be screwed into place.
Thanks
Thanks
Hi Mike,
Here are some photos. Black net and black trunk is a bit hard to see. But the vinyl bag holds the net when stored and the bag is bolted in place. You can see the silver anchor on the right in one pix.
Even when the net is deployed the bottom is attached inside the bag so it is always in the way of lifting the cover for the spare tire.
Thanks
Thanks
Ha, well that makes sense! I checked and you are correct. What I missed was that the chrome anchor rings are fitted inside pouches on the rear of the bag and the pouch is snapped closed.
Nice clean install that hid the way things were connected. Thanks for clearing that up for me!
The cargo net came installed on my 2014 ES350, but because of your issue and just routine "getting in the way" I permanently removed it. I have had cargo nets on other cars I've owned, but they were not obtrusive and were easy to "hook into" place when needed, but also easy to move out of the way. I even made mention of this on my JD Power and Lexus new buyer surveys.
If you haven't actually looked for the storage bag, check again. I've had my 2013 ES for 2 1/2 years, and I never realized that there was a storage bag for the cargo net until I read this thread and went out and looked for it. Sure enough, it is there at the bottom of the cargo net.
Ya, that bag integrated into the bottom of the new is weird. Never have seen something like that on any of the 3 or 4 other cars I've owned that had cargo nets.
Mine came lying loose on the floor of the '13 CPO car I just bought. I didn't realize about the chrome securing rings, though. I'll have to check them out tonight.
Angle parked in a parallel universe
My question is, why are you so intent on getting into the spare tire well? If you aren't mechanically inclined enough to find 2 snaps and undo them, I would say that you should leave other slightly more advanced projects (like changing a tire) to professionals. Ya know, like the people with Roadside Assistance. It's a free service as long as your car is under warranty, and since your car is a fairly recently purchased '15, you can just push the SOS button and someone will come on the line to assist you.
The important thing here is that he received an answer from the kind members of this forum.
Lighten up...
