ES350 2015 - how to turn ON the heat without the AC?
Doesn't using the A/C compressor also use more gas and affect mileage? Maybe it's a miniscule change, not sure.
Also, interesting that some ES's have the A/C hard-button and others do not.
- Mine has the Nav and ML, and no A/C button on the dash.
- I had a loaner NX (with Nav), which has the A/C button.
- My wife's 2015 RX (Nav, no ML) does not have an A/C button.
- The 2016 RX I looked at also did not have an A/C button (Nav, no ML).
Mine's a left-hand-drive global export model, it has English/Chinese/Arabic text on all the stickers. I think mine has the AC button because it came with only the black and white display, no Display Audio or Nav. I sat in a few 2016 ES with Display Audio and none of them had the AC button. The whole control layout mess seems so arbitrary when Lexus/Toyota could have used one climate control stack for all variants.
Using the A/C along with heated air serves two purposes; first, for those of us in cold weather states, when the temp gets below say, 30 F., you don't require A/C until such time that your body, breath, and heat create humidity inside the car which fogs the windscreens front and back. The A/C eliminates this condition. When the imbalance - cold glass and warm interior - dissipates, the A/C is no longer needed. The auto setting provides dehumidified warm air when calling for heat which = no window fogging... Like Mike I leave my settings on "auto" believing that Lexus engineers are usually smarter than me...
My personal preference is to always use outside air and A/C OFF in the winter. I do this because of the following:
1. You are utilizing the engine heat and can heat the car faster with outside air
2. You are bringing in dry air from the outside, which has always eliminated any humidity concerns for me (at least in this part of the country). I typically have a car full, and never see any fogging issues.
3. It's not recommended to use A/C compressors in temps below 40F (at least for central air, home compressors).
See the last sentence here from the manual:
Fogging up of the windows
●The windows will easily fog up when the humidity in the vehicle is high. Selecting
on will dehumidify the air from the outlets and defog the windshield effectively.
●If you turn off, the windows may fog up more easily.
●The windows may fog up if the recirculated air mode is used.
The car has a nice warm engine in the engine bay, so you really shouldn't have problems running the A/C in the winter, and point 3 above is probably irrelevant. Still, just my preference.
I wouldn't want to criticize too much, but I am not in a cold climate.
Also - the temperature adjustment doesn't work correctly when the AC is OFF, for for instance - today I had 56F outside, the AC was OFF and the temperature set to 76 and the vents blew hot air. I had to keep going down until LO - to make that stop.
This car is either undeveloped or is lacking adjustment precision or is full of engineering shortcuts. Or broken.
Oh Thank you very much. Yes indeed I was able to shut it down!!!
Funny thing is that when I read the manual - there was a figure on page 82 which I obviously misunderstood.
The manual should have been clear to the point to say - move the cursor to 3 dots, click on it and click on the AC.
Well, this technology is too smart for owners like myself.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I would rather have a button.
Thanks, again
Thanks, again
Epic123
04-19-23 08:22 PM
pmnuon79
01-05-17 08:37 PM
L8Apex
02-14-12 06:52 AM
