ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
6th Gen ES 350 Center Console Removal/Disassemble
Old 03-05-16, 07:42 AM
frsmith2
frsmith2's Avatar
Default 6th Gen ES 350 Center Console Removal/Disassemble
My center console, especially around the Display Audio Controller, has some gunk in it that can only be cleaned by removing and disassembling the console.
Problem is, I'm not finding good info on how to do this for the 6th Gen (2013 - ) with Lexus Display Audio controller.
Any experience you can share? I've seen the 5th Gen videos, posts, etc. but so far no luck with 6th Gen as the console is very different. Thanks.
Attached Thumbnails 6th Gen ES 350 Center Console Removal/Disassemble-img_3545.jpg
Old 03-05-16, 08:29 AM
jollick
jollick's Avatar
Have you tried a vacuum with a concentrate nozzle? Perhaps a moist Q-Tip will help.
Old 03-05-16, 08:57 AM
Dave Mac
Dave Mac's Avatar
I would try a lot of things before removing the console to solve your problem.
Dave Mac
Old 03-05-16, 03:55 PM
12jimmyjam
12jimmyjam's Avatar
I've used tuff stuff or a foaming glass cleaner (without ammonia in it) before on other vehicles. You spray, agitate with a soft toothbrush, spray again, and then suck everything out with a shop vac. It's worked on a lot of stuff for me.
Old 03-06-16, 05:37 AM
TechNut
TechNut's Avatar
Dave Mac
Agreed. The plastic bits and parts rarely fit back together as tightly and completely as the factory fit. You could induce squeaks or rattles by dismantling. I would certainly save that for an option of last resort.
You might consult a detail shop as they will defitely have ideas on how to clean it out and I guarantee you they will also shy away from dismantling it. A good detailer will have various tricks for getting those tough spots.
pakrbakr
RX - 3rd Gen (2010-2015)
01-04-16 06:20 AM
Aliceto
GS - 1st Gen (1993-1997)
03-13-15 08:30 AM
aids21
04-02-04 09:08 PM
ES Boy
01-05-04 02:36 PM
Quick Reply: 6th Gen ES 350 Center Console Removal/Disassemble
