Subwoofer Install
Hey all,
Anyone have a detailed description as to what it takes to install an amp and sub in the trunk of the ES300h? I have the non-ML radio and it's seriously lacking in the low-end sound department!
The battery in the trunk makes it easy to hook up the power cable but I'm lost when it comes to the remote (signal) cable and the RC cable hookups. I'm sure someone on here has brought this up before but I couldn't find anything while searching. Thanks in advance!
I’m trying to find info for a DIY sub swap. Have you had any luck? It sounds easy enough. I just need to tap into the source, sum the channels and feed that to a new amp for an aftermarket sub... right???
Let me me know if you have had any progress
DaPope10
06-28-20 06:20 AM
nysupraman
05-14-05 07:54 PM
