ES 350 2015 A/C Problem
A/C in my 2015 ES350 (25K miles) has failed 2 times.
1. Outside temp 92 Deg. I start the car and turn on the A/C. It is pumping hot air. I wait 5 min. It is still pumping hot air. I switch it off and start again. It pumps cold air.
2. Outside temp 94 Deg. I start the car and turn on the A/C. It is pumping hot air. I turn it off and on. No luck continued to pump hot air. Next morning out side temp 77 Deg. I start the A/C works fine.
I took it to the dealer. He says unless he can see the failure he cannot do any thing.
Any ideas/clues are appreciated.
Time to let the dealer sort it out.
Try driving it in normal or sport mode for a day or two. If it comes on then, at least you will have some important information for the dealer.
These cars do funny things in Econ mode
colinodon
04-08-16 04:40 PM
