Trunk chrome trim
Well I was finally successful in removing the chrome bar and began dipping here are some in progress pics, I will post more in a new thread you can check out
You can reach one 10mm nut with a socket, the other 2 will need a 10mm wrench to access, Why they couldn't make the panel big enough to access all 3 with a ratchet is beyond me.
Wrap came out good. Still need to do some minor things on it when I get back to Vegas. Only had about 30 seconds of sun today so grabbed a few pics before the rain started.
Originally Posted by Ratchey
Looks good. To remove the tail lights, there is a plastic panel on each side of the trunk behind the light. Remove the panel. twist out the upper light bulb and then disconnect the small white harness.
We wrapped them. It was an extremely time consuming process. The rear chrome piece took about 90 minutes.
2 hours to do the rear wing. I need to redo the logo. Some chrome is showing through. It is all wrapped in a matte metallic gray that matches the magnetic gray Toyota uses. We wrapped the mirrors in the same color with a matte black facing the inside.
taimysho0
RX - 4th Gen (2016-2022)
02-25-18 08:44 PM
