255/40R18 Tires on ES350
Has anyone upgraded to a beefier tire like a 255/40R18 on the 18" rims? If so do you prefer the wider look and any pictures?
Thanks
Thanks
Top of the page, “Tools”. Dropdown menu “Tire Rim Calculator”. Or try https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm for more detailed comparison. Just plug in numbers for stock and info for “thinking about” and see what comes up.
st1800 (08-20-23)
Thanks for that calculator. Using the calculator i wasn't sure if the various clearance were correct ( fender, suspension, wheel well ). I was able to see that a 235 45 18 will work just fine in the situation because it was one of the wheel offerings.. For the increased power i wanted to fit a 255 in there, so i'm still not able to tell.
jgmcs
03-04-07 08:39 PM
