help with front led turn signals install
hey, has anyone on this forum done a front led turn signal conversion on there 6ES. if so can you guys tell how you did it, i tried going through the wheel well and it was a PITA. so any help will be greatly appreciated.
With all the changes, add-ons, and deletions you're trying to do with your car I would strongly suggest you get the shop manual for your car. Then you'd be able to see photos and detailed instructions.
AGAIN................why change all this ....First of all LED turn signals dont work because of hyper flash, so u either need replays or very expensive bulbs that have the relay built in, then not sure they work correctly.....Just change the back up lights and the interior bulbs and puddle lights and leave it alone..My opinion of course.......Sounds like what I did as a kid with my 57 Chevy.
Grab the outer edge of the glass and pull towards the car as far as it will go. Then reach as far back behind the glass as you can and carefully pull away. There are 4 sets of double clips and some white paste holding it in place. Be very careful as it isn't hard to break the glass ($500 + part)
There are 5 screw visible. Only 4 need to come out. The lower one closest to the vehicle can stay.
Carefully separate the back mirror cover and pay attention to how the turn signal and puddle lights are attached. There is no screw holding them in. They can be difficult to set back into place.
Replace the bulb and reverse the process. The puddle light is difficult to set into place. There is a small recess on the back of the light housing that fits in a weird way. Pay attention to how you take it out.
Reinstall everything, then with the mirror glass, you need to try to look behind it to align the clips closest to the car. Then carefully press against the mirror towards the center until you hear it snap into place. Then pull on each corner of the glass to make sure you got all 4 clips connected.
For the door puddle lights, you need to remove the door panel to access the clips to pop the lights out. Use your finger to release the clip. Using a tool will most likely break the clip. (I know this first hand and so far I haven't found an adhesive that will reattach the clip)
Then take the light apart, replace the bulb, put the door panel back in place, making sure the wiring can be reached through the hole and that the wiring didn't get caught below the door panel (can you tell I have done this a few times)
Then reattach the harness and carefully insert the light housing, harness side first, back into the hole.
Originally Posted by Ratchey
To change the puddle lights in the mirrors, you have to have a strong soul.
Nope. If you can't access them through the fender well, it means removing the bumper and headlamps. Something I have not been willing to do so far. Removing external body panels rarely works out well. They never seem to fit back together the same.
The rear turn signals can be changed out to LED's without relays, resistors or anything other than a new socket. Did it 3 years ago and still going. I posted the equipment previously and it works perfectly without hyper flashing. I did not change the front signals.
https://www.clublexus.com/forums/es-...-or-not-2.html
That is correct. Toyota/Lexus in their infinite wisdom felt it necessary to stash the signal and parking lights in the inner fender area. So it can't be reached from under the hood. You have to reach it from the fender well in front of the tire and have really small hands and long arms, or you need to pull the bumper and remove the headlight assembly. Neither way is very easy.
Replace front turn signal bulbs
Ok to start off I know I've posted previous thread about this with no help at all. I'm back once again because I wanna change my front bulbs to led and I am having hard time getting to them. Can someone please shed some light on this?(oh and please don't post the instructions from the manual)
