help with front led turn signals install
#31
Originally Posted by trama09
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/512x1236/untitled2_c8030cc4645347bdea1d536469741210f315c471.png)
It's in the manual. And like Brent said - hyperflashing. I just received LEDs today and forget it might need resistors. Nearly got a seize from the hyperflashing
#32
I replaced the front and back bulbs. But took them out for these: http://a.co/8oG73sq
They're not just bulbs, but have the resistor (small-brick) included with them too. I didnt want to buy resistors by themselves and crimp the factory wires. So this "all-in-one" assembly was the next best thing. And they work perfectly. Only down side is that the socket is hard rubber and you have push it through (to the grommet) instead of twisting and locking. But they havent fallen out or anything.
#33
#35
FWIW I've been running leds for my front and rear turn signal for over a year without trouble in my 2013 ES300h. I did go through the wheel well for the fronts and it was a tight squeeze getting my hand in there, but I eventually got them all in there. I used a resistor on each bulb because (a) they're super cheap, (b) they are plug and play, and (c) they eliminate the bulb out and hyper flash issue. I used the "switchback" style bulb that you'll see if you check eBay, but I leave the DRL option disconnected (so I only use amber). They were the perfect form factor for our housing after experimenting with a couple different styles. These are the ones I used: http://www.ebay.com/itm/2X-5730-Dual...-/291337827565
I just can't stand incandescent turn signals on luxury cars, looks so cheap.
#36
E46CT
06-18-20 09:05 PM
KennyZ
02-20-18 08:27 AM
