DIY maintenance questions
Not Jiffy Lube for the hybrid...
It cost me a fair bit for the 2-year brake fluid replacement on the hybrid. I saw the Lexus techs doing the work and it wasn't like the simple brake fluid bleeding on other cars. The hybrid has to be hooked up to a Toyota diagnostic computer to open the fluid valves on each wheel in sequence and the system has to be primed again. I think it took 2 hours just to do the brake fluid. At least you won't have to worry about replacing pads or discs because the hybrid uses motor regen for most of its braking.
Oil changes are simple though, just put the car on a ramp and change the oil filter.
jollick (12-31-16)
Oil and filter changes are within the realm of DIY mechanics. Brake pads and discs should last for 100k miles or more because the hybrid rarely uses friction brakes.
I'm working on (or more likely monkeying around with) an Android app to pull hybrid-specific data like motor temps and battery health using the OBD port. It's the same data available through Techtool but it's a lot more convenient to use a phone and a Bluetooth OBD dongle.
Inverter coolant replacement and CVT/PSD fluid flush, I guess. Those are hybrid-specific parts although any Toyota dealer should be able to service those bits, as they're also shared with the Camry and Avalon hybrids.
I have a 2010 RX450h with 70K miles, and the brake pads are at 95%. If you brake softly, most the braking will be done by the regenerative braking. I have never seen any brake dust on the front wheels. The whole braking system looks so brand new, and I expect to never have the need to replace the components (other than changing the brake fluid).
I read somewhere that a Camry Hybrid owner tried to do a brake fluid flush himself and completely messed up the system. He ended up paying $600 to get the system properly flushed at a dealer and to get some components replaced. That said, it's within the realm of the advanced home mechanic with Techtool and some specialized bits.
Ya, just like math, working on system with ABS and Traction Control is hard...
My karma just ran over your dogma
Current Hers: '13 Lexus ES350
Current Mine: '08 Jaguar S-Type 4.2
I admit my wife does a lot of stop and go driving on her daily commute, but still it was unexpected. I know how I use brakes on a hybrid, but not sure what she does.
Curated Content Editor
Maintenance
10-25-18 05:26 PM
