ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Removing Oil Filter Housing
Old 12-30-16, 04:27 PM
jdsu
jdsu's Avatar
Default Removing Oil Filter Housing
Has anyone had any trouble removing the oil filter housing on our 6th gens? I was attempting to change the oik today and coukd not get it off. I am using the special tool needed as well. What is that thing torqued down to?
Old 01-01-17, 10:09 AM
bc6152
bc6152's Avatar
Received 1,289 Likes on 897 Posts
I've changed the oil on my 2013 350 numerous times and if this is the model you have, the housing is the same. I use a regular Pep Boys oil filter wrench and simply turn it off part way to let it drain, then remove the whole housing with the cartridge inside to change it. When finished the housing is turned on until it's seated and the "O" ring is compressed. Some members remove the small fitting on the bottom of the housing along with a tube to drain the housing first. This is also correct. The filter cartridge housing is not torqued, it is spun on until seated against the engine.
StanleyR
01-06-20 09:49 PM
meffaman
RX - 3rd Gen (2010-2015)
26
08-22-19 04:59 AM
highvoltag
NX - 1st Gen (2015-2021)
17
04-17-18 07:58 PM
yeehawbob
Hybrid Technology
17
05-20-13 08:47 PM
yeehawbob
Maintenance
03-12-13 07:22 PM
Quick Reply: Removing Oil Filter Housing
