ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
HID bulbs
Old 01-03-17, 10:12 AM
drmull2
drmull2's Avatar
Default HID bulbs
I got a '14 ES with whatever package includes Nav, heated & cooled seats, and wood trimmed steering wheel. I'm confused about the headlights. I thought this package included HID bulbs... not necessarily adaptive lights but at least HID bulbs. My low beams are definitely halogen. Did I have it all wrong about the Nav package??
Old 01-03-17, 10:21 AM
lesz
lesz's Avatar
Received 1,015 Likes on 693 Posts
The HID headlights have always been an separate add-on option with a MSRP of somewhere around $500. With some equipment combinations, you are required to buy the HID headlights, but they are still listed as a separate option in the build.
Old 01-03-17, 10:50 AM
drmull2
drmull2's Avatar
Okay. Bummer. I bet I couldn't have them added now for $500! Oh, well.
Old 01-03-17, 03:26 PM
dchar
dchar's Avatar
One option is that you can order a kit and install it yourself.
Old 01-03-17, 03:41 PM
Kijug
Kijug's Avatar
Yea, this is funny. I got the '14 ES UL/ML with HID headlights...yes, it was $500. So I researched and if you added the HID lights later, it is like $1500 a piece, IIRC--regardless, it is super expensive to fix/replace later. So I asked the salesmen--partly tongue-in-cheek, partly serious, tho I know what he was going to say--I asked him if the HID lights at time of purchase are only $500, can I buy a second set for later when I have to replace them. He obviously said "no". Heh...
Old 01-03-17, 06:59 PM
drmull2
drmull2's Avatar
I would be willing to install a conversion kit if they actually work. If anyone has actually done it, what are the trouble areas?? The bulbs are 4300K, correct? And...if I install a kit for the low beams only, does it affect the wiring/connection of the high beams?
Does this kit look decent? Thanks!
It's a 55W kit. Not sure if that's necessary...or if I should do a 35W?
http://www.carxenonhidkits.com/low-b...h-halogen-2014
Old 01-04-17, 03:09 AM
BigRon12
BigRon12's Avatar
4300k is the Temp/color.
The bulb type is D4S (someone confirm that)
The hid kit is very simple to hook up. I would personally go with 6k...white with a hint of blue.
Old 01-04-17, 03:29 AM
thoiboi
thoiboi's Avatar
Stick with 35W
Also check out www.theretrofitsource.com for their Morimoto kits. They blow the competition out of the water with warranty and unparalleled quality.
Old 01-04-17, 05:03 AM
Mike728
Mike728's Avatar
That would be a costly mistake around here. You would be given a ticket and have to prove to the courts that you changed it back to factory.
Old 01-04-17, 06:31 AM
Brent1944
Brent1944's Avatar
I dont know why u cant do it yourself unless this car is magically different than others.. I put them on my Honda Pilot.. I added HID for Low Beams, left Highs alone.. Added LED fogs....My 2016 has BI LEDs so Im leaving mine alone..Got mine from..http://www.xenondepot.com/..Im not saying this place has what this car needs, But all the Honda Pilot people got theirs here....well most of them did.. A few went with Morimoto .
Old 01-04-17, 07:43 AM
drmull2
drmull2's Avatar
Thanks for the helpful replies.
Now... I see lots of videos about adjusting the adaptive headlights, but what about the halogen housings? I read about possibly needing to lower them a bit once the HIDs are in.
Old 01-04-17, 07:59 AM
Brent1944
Brent1944's Avatar
I left them alone in my pilot..youi will just have to ck the cut off line.. you will also notice when oncoming drivers flash you
Old 01-04-17, 08:56 AM
jollick
jollick's Avatar
To be sure you have the HID headlights or not see this thread https://www.clublexus.com/forums/es-...-and-ul-3.html
I posted photos of what you will see when looking at the back of the HID light housing. It you car looks like the photos, you have HID.
Old 01-04-17, 11:49 AM
drmull2
drmull2's Avatar
The Morimoto kits look very good (thx Thoiboi). I'll go with that. Hope they work!
Oh...the up/dwn adjustment for the halogen housing is easy. Sorry I didn't look before I asked.
lextout
10-16-16 04:00 PM
concac
ES - 5th Gen (2007-2012)
10-06-15 06:07 PM
BBLexus
Lighting
12-26-07 09:55 AM
LS4Lexus
10-31-06 08:06 AM
ShadyJC
Lighting
09-25-04 10:57 PM
Quick Reply: HID bulbs
