10,000 mile service issues
The work order for my 10K service does show a separate listing for the cabin air filter and the tech did mention that they changed it because it is part of the 10K free service but that it was pretty clean and probably not necessary to change it every 10K. These filter elements are really expensive from Lexus and they keep recommending shorter and shorter change intervals. Rotating the tires however is still recommended every 5K which is probably a good idea - but maybe not at your Lexus dealer when many tire stores will rotate your tires for free. I usually watch them do the work but also note or mark something about at least one tire or wheel to confirm the rotation is done - and they have never failed to do it.
Dave Mac
Dave Mac
12MO / 10K MI
COMPLIMENTARY / FACTORY-RECOMMENDED
• This service is normally covered under warranty if done within 12 months or 10,000 miles.• Replace engine oil and oil filter (0W-20)
• Rotate tires and adjust tire pressures as required
• Reset maintenance reminder light
• Road test vehicle
• Check installation of driver's floor mat*
• Visually inspect brake pads, calipers and rotors
http://www.lexus.com/maintenance
Sounds like you have a good dealer, as the filter is not included in the free service.
• Road test vehicle
12MO / 10K MI
• Road test vehicle
What area is your dealer in? Definitely wasn't included when I had mine done in Schaumburg back in 2014.
I do have a good dealer but I think on the 2016 changing the cabin filter at the free 10K service is listed in the manual as something that is included. I don't recall that being the case with my 2013 ES though.
Dave Mac
Dave Mac
Mine is a 2016. It wasn't listed on the invoice, so I'm not sure they changed the air filter.
This is Northeast PA area. .
The service advisor said nothing about it, and I've been calling him for two days now. I may never be able to
find out if it was changed, unless I take it out and look at it I guess.
It was mostly city driving, so it's possible it needed changing.
It sounds like it depends on the dealer, and also how 'dirty' it looks.
JL
JL
Had my 10K service this week as well; the only fault was messing with the tire pressure. I had them perfect at 33 cold and when I got on the road fronts were at 37 and 38, and backs were at 36 and 37. And, they did not replace any filters other than oil...... but we got cookies
My dealer service experience is similar regarding filter changes. At my 30k service they said the engine air filter was getting close to needing a change but could wait until 40k. I plan on picking up a new filter somewhere else and swapping it myself (quite ease to do). I checked the cabin filter myself before taking it in and it was still in good shape.
Lexus drivers ought to have a good basic knowledge in vehicle maintenance. It is pretty funny this kind of topic come up in the forum. Sounds like many are vehicle
operators among us.. I used to drive Bimmer, Audi, Porsche, etc. when I was young . Their corresponding forums are different compared to that of Lexus. We are drivers of our cars/trucks not operators.
USALV (03-09-17)
Hello Lexonians,
Well, I took my 2016 ES350 in for its official 10,000 service yesterday. Of course, when I got it back everything had been reset/erased
as far as the computer and settings go. So now I have to rediscover how to reset them.
But I noticed on the invoice it says 'Replaceable element' and 'Gasket' as separate line items. I wonder if this is a normal part of an oil change? Is the 'Gasket' used to keep the oil from leaking? Just wondering if you guys had the same experience.
Also, the right mirror was totally off. When I got home I discovered it was loose. Moving it towards the car seemed to 'click' it into place, so hopefully it'll be OK. Maybe they had to fold it in or something when they did their magic w the oil change?
In the future I think I'll just take it to Jiffy Lube. I don't see why they have to reset everything in the car, and also it takes literally
2+ hours of waiting - just for an oil change.
John
John
Did everyone just wait until 10k for first oil change? Some people are advising me to do it at 7500mi and that letting it go to 10K is not a good idea if I plan on keeping the car for awhile. Any advice from all you long time Lexus owners would be much appreciated. Planning on keeping this car for awhile so wondering if I should consider more frequent oil changes? Thanks in advance for sharing your experiences!
Thinking about 10,000 miles oil changes takes some adjustment - I remember when there were 1,000 and then 3,000 mile oil changes - but I would feel confident with the 10K recommendation. There is a range on the free 10K service but I'm not sure it goes town to 7,500 miles unless you are near 12 months. My son has a Denali and a Honda Accord and I don't believe either of them has a recommended change - they just tell you, and it seems to be around 6,500 of city driving.
On the other hand 7,500 miles oil changes would never do any harm except maybe to your wallet and the oil supply..
Dave Mac
Dave Mac
