ES features you did not know about.
#121
Here’s a good one for those with the electric / power closing trunk:
If you need to transport a long item that will stick out from the trunk (recommended for short distances only!:-)), you can try to close the trunk using the button - it won’t work and just re-open after hitting the item that sticks out.
If you now just start driving, after a short while the trunk will close by itself as far as it can and basically push itself against the obstacle and hold itself closed as much as possible - how cool is that 😎!
A warning beep will continue going while you drive, but at least you can drive home.
Hasman69 (07-15-20)
#122
#123
For those of you who drive their ES in the winter in snow, you may have noticed that when it is snowing, the snow tends to accumulate on the front parking sensors and when the car slows down or stops at a light the parking system beeps, complaining that you are too close to the object in the front. For 5 years I ignored this, and only this year figured out that the parking system can be turned off by the button on the lower left side of the dash.
This kills the beep when driving in the snow.
It only took me 5 years to figure this out :-)
#124
my favourite feature
2018 ES replaced my 2008 ES and this worked on both. To open all windows and the moon roof on hot days to vent the heat while walking to your car, do this! Once in range the lights will flash and you push and hold the unlock button on the remote. After a few seconds the car will beep and the windows and moon roof will open as long as you hold the button. This makes a huge difference and allows cooler air to enter as soon as you drive away. Once the car temperature is the same as the ambient, turn on the climate control and close the windows. If this doesn't work, have your Lexus dealer programme your fob at the next service or do it yourself on your navigation screen under vehicle settings.
As an aside, the super heated air inside a car has toxic fumes from volatile materials in every car. Allowing these to vent is probably a good idea!
#125
If you program your garage door to open/close using the Home Link buttons under the rear view mirror, there are actually 2 lights with arrows that come on showing you if you are opening or closing your garage and the cool thing is they blink yellow when your garage door goes up or down and turn solid green for a few seconds when the door is open/close all the way. For peace of mind when driving away, I used to look back when I get to the end of the street to make sure the garage is closed all the way but not any more. I just glance at the light and if its green, its closed.
#126
That, btw, only works with later versions of door openers. If your opener is old it won't have bidirectional communication, so your Homelink transmitter isn't broken if this doesn't work for you.
#127
#128
Check your owners manual for “Customizations” or “Customizable features”. You should find a chart that shows what you can change yourself, depending on your options...or what you might need either an OBDII reader/programmer (search “Carista” on the internet) or a dealer to program. It’s found about page 869 in the 2014 manual.
#129
#130
#131
Just bought a 2016 and havent a clue how to use many of the features.....thanks for this post......
so far the mirror joint thing is cool
winter mode for the wipers is cool
Learning to put the car in accessory mode is cool. In another car that i drove diff MFR the sales person hit the start button twice for accessory.......I wouldnt dare do that to my new car without knowing.
#133
Turns out the headlights (at least the HID ones) have motors in them and can adjust up/down based on how loaded the car is. There is a sensor on the rear right control arm that measures how much the car sags. I was able to activate the motors in test mode in TechStream and make them move - pretty neat.
AFAIK this system is mandated in Europe and it was easier for Lexus just to keep it on the US-spec cars as well.
#134
#135
Here is the illustration from the USA 2013 ES user manual. Look in your instrument cluster for this light to illuminate during startup - I would bet your car should have it.
UPDATE: Just tested the system in my garage and could see it work without Techstream: 1. Start the car or better put it in the ignition mode (hit the start button twice without pressing on the brake pedal). 2. Step outside and put your weight on the trunk lid - this will slightly lower the rear end of the car. 3. Within 1-2 seconds you would see the headlights self-adjust and hear the headlight motors buzz (here it helps to be in the ignition mode so the engine is not running).
You can also check if you have the suspension height sensor behind the muffler.
