Lexus navigation volume
On my 2006 Lexus when the navigation voice would give directions the driver speaker volume for the radio would be minimized.
My 2016 Lexus es-350 does not do this. Is there a setting to do this?
To adjust the volume for the Route Guidance on your navigation system, please use the following steps:
1. Press the “MENU” button on the Remote Touch, then select “Setup”.
2. Select “Voice” on the “Setup” screen.
3. Select the desired level by selecting the appropriate number. If voice guidance is not needed, select “Off” to disable the feature.
4. Select “Save”
I hope this helps.
4. Select “Save”
4. Select “Save”
AFAIK, there is no way to do that which is kind of bush league.
