2014 Lexus ES 350 Door Replacement / New Or Refurbished / Body Shop in Question
People i need help,
Got my black ES 350 from the body shop replacing rear right side passenger door, insurance paid for the original part however upon visually inspection of the installed door, i notice that there is seal sealer on the door, and looks like welding work done, i know its illegal to install refurbish doors, is anyone have experience with this, i have attached pictures, very suspicious door... Shop owner gave me copies of invoices from Lexus ...i dont know what t think
The body shop may have just replaced a skin and not the entire door. This is how a previous Accord was repaired when the door was hit. If you were billed for a new door then you may have a problem.
There are really only three ways to repair a door. Used door, you should be able to see where it was repainted unless it was the same color, Pull the dent and refinish or replace the door skin. The door skin is the most common, you will see weld spots. But in most case these should be covered with seam sealer. Compare the seam on the left rear door to the rear passenger door. They should look identical. If not then I would ask them to re do it. Plus your bill should have a parts list. You can check that number to an OEM. If they gave you an after market skin, your insurance company should tell you. These are generally are inferior steel, fit is not as good.
Body shop provided invoice from Lexus part 6700333220 DOOR SHELL, but its very weird that new original replacement door comes with seam that sealed, they prob switch door in process and replaced with refurbish one
