2013 ES350 Driver Door Doesn't Lock
Has anyone had an issue with the driver's side door not locking when using the remote/door? I can lock/unlock manually but it will not lock/unlock if I try it at the door handle or the remote.
Someone had this issue previously. It was found to be a defective actuator. Don't know if this is the same but symptoms are identical.
I believe that the dealer wanted around $800.00 to fix it.
