2017 es Radio setting on startup
Some background. On non-Nav system, our Audio/Radio displays 6 channels per page. I may be listening to the 3rd channel, and it is highlighted. When I turn the car off, the highlighter always goes to the first channel on that page. Yes, the channel remains on the 3rd channel, but the highlighter ALWAYS goes to the first channel.
Is this a software issue or does everyone have the same experience? Starting to annoy me....
Thanks,
David
Thanks,
David
Thanks,
David
Thanks,
David
Dsvetcov: when you select the next channel with the steering wheel selector, does the station go to 4 or 2 or does it restart from 1 as highlighted?
If I remember, I'll give it a try tommorow on mine with nav to see what happens.
Thanks. When using the steering wheel selector, highlighter does not move, BUT, (I will call it) a dimmer channel selector moves to the respective channel. The only way to progress highlighter is to use the mouse (or turn **** without nav). .
This is less than desirable user interface (UI). Needs to be a software fix or other.
Thanks,
Thanks,
Slbenson
ES - 6th Gen (2013-2018)
08-29-17 08:44 PM
