New to Me ES350. My Questions Thread. Pls Help.
That's the point, 5500k bulbs are not brighter than 4100k bulbs, they are dimmer. That's physics, the higher color temperature has lower light output.
Well documented on the internet.
As I said, if you care about light output you should purchase a bulb with the highest amount of lumens, not the highest color temperature.
You are also incorrect that the brighter bulb "can be aimed further down the road", you don't understand how the projectors are designed. They deliberately cut off projection down the road to avoid blinding incoming drivers. That's why HID bulbs have such a sharp cutoff compared to halogen bulbs, that's by design. Your current bulbs are the brightest bulbs (in terms of output) you will get, lighting up the road further down is just a function of aim.
Is this your first car with HIDs? Take some time to get used to them. You will get used to the cutoff. I've had cars with HIDS for almost 20 years, I've only had to adjust the lamp aim on one car, my 2013 GS, and only slightly.
You can move the projection down the road by adjustments of the aim upward. And a brighter light is brighter.
And not all HID projectors cut off blinding on coming cars. There are a few cars and truck out there that the factory HID systems blind everyone on low.
Thanks for your opinion. So what blub would you suggest, that has highest amount of lumens, not the highest color temperature????? That's what I would like to know. That would be helpful.
Originally Posted by jgscott
LOL! 1st car with HID's 2002. I think. And I never said that 5500k bulbs are brighter than 4100k bulbs. Not sure where you got that from? And FYI people do have variable eye site.
If you want brighter bulbs, and you purchased 5500k bulbs it only makes sense you would think they were brighter.
It's important to note that with a physical cutoff designed into the projector system a brighter bulb WILL NOT project any further down the road. They bulbs you have are capable of projecting much farther than they do, they are physically blocked by doing so.
I already told you what I recommend in an earlier post. I would look into Osram CBI (Cool Blue Intense). The name is terrible, they aren't blue at all. They're a 4,800-5,000k color temp which is whiter (no yellow, but no blue) while still putting out 3,100-3,200 lumens which is what a 4,100k bulb does. Osram makes the OEM bulbs also, at least the ones in my LS.
I did a ton of research before I bought these and read dozens and dozens of sources. I wanted better color and brighter light to match my LED fogs better, but I didn't want to give up any output, these were the only game in town. Now there are a couple competitors with a similar product.
https://www.theretrofitsource.com/bu...66440-cbi.html
These statements are not logical. You have said you want brighter lights. You purchased a set of Morimoto 5500k bulbs, which are in fact dimmer than the OEM 4100k bulbs. Do you see where that doesn't make any sense?
Yes they do. Any system that does not have a cutoff would not be DOT legal in the United States. In any event we are talking about your Lexus which absolutely 100% has a cutoff. Some cars may blind you, but they still have a cutoff it's just designed differently or the owner has re-aimed them as you're trying to do.
It's really not an opinion, if you do a little googling and research on your own you will see that I'm correct.
Thanks for your help. FYI: There are many blinding factory lights out there right now. The GM pickups and even the New Corollas and others.
Can't speak to the GM trucks, but new Corollas have LED lights, not HID lights. Entirely different technology. I can't say I routinely see any cars who's lights I think are blinding.
Again, thanks for your opinion. I beginning to think that no light would be brighter unless its higher voltage and watts. I appreciate it.
Can someone tell me how to change the dash indicator from avg mph, back to the blue bar that shows fuel economy as you drive? Somehow its on avg mph now.
And also is there a miles to empty in the gas tank readout that I can see? I cant find anything or place that tells me how many miles in fuel I have left.
The DISP button on the right side of the steering wheel will change what is displayed on the dash screen. Push it multiple times and it will cycle thru several parameters like the 'blue bar' current fuel economy, mpg after refueling, avg speed, tire pressure... etc.
jgscott (09-16-17)
Now next Dumb question. And I have searched.
I have a iphone 6s. I also use a Bluetooth Headset. I looked in all the displays.
Is there a way the tell the Lexus Car Bluetooth NOT To Automatically Connect to the phone when I get in the car?
The iphone does not have a setting for a single Bluetooth device that I can find?
I believe you need to go into the Bluetooth setup in your car settings, and remove your phone. As long as it is paired, I think it will try to connect. It sounds like the phone finds the car before it sees the headset, but I don't think there is any way to control that behavior from the perspective of the phone. Let us know if you find another solution.
ebailey
ES - 6th Gen (2013-2018)
11-30-15 05:32 PM
PERRYinLA
12-04-05 03:24 PM
