ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
alternator death
Old 12-25-17, 06:05 PM
lesz
lesz's Avatar
Received 1,018 Likes on 696 Posts
Originally Posted by wontonly
Thanks lesz, I just purchased the CPO at 52K miles. Would the free repair still apply?
I don't know. I think it would depend on the good will of the dealership, but, if the dealer does not seem to be cooperative, I would certainly pursue the issue Lexus corporate. Also, I think that you should be able to make the case that the CPO warranty is still in effect.
Old 12-26-17, 08:44 AM
Mike728
Mike728's Avatar
Wow, this bulletin seems to apply to the VIN for the one I just got my parents as well. Will tell them to bring it in next time they get their service.
Too bad Lexus can’t just automatically identify, contact the owners, and fix these things. With my experience, I’ll probably end up paying an exorbitant repair bill and the dealer won’t even mention the bulletin.
Not every vehicle that is within the VIN range will have the issue. Does your parent's ES show a history of battery issues? Have they let it sit for a few days and not been able to start it without a jump? I had the issue and it was very obvious.
Old 12-26-17, 01:14 PM
Popgun
Popgun's Avatar
Originally Posted by heidihidin
2132265 lower right?
Yes, lower. Like Mike says, you may not have that exact problem though. But if you do, the TSB should apply.
Old 12-26-17, 11:49 PM
Poppa
Poppa's Avatar
So here's my question. My vehicles VIN is lower which means it falls within the range of the TSB... However, I have never experienced any battery issues and I am coming up on the 4 year anniversary of when I bought the car. My 48 month warranty will expire on Jan. 9, 2018. Even though I've never had battery issues should I still take it in or not worry about it. I"m planning on putting in a new battery in the next 2 to 3 weeks.
Roland
Old 12-27-17, 05:16 AM
bc6152
bc6152's Avatar
Received 1,306 Likes on 909 Posts
My VIN is also within the replacement gateway range. However the battery is over 5 years old and I've never had an issue with that or anything else... Just luck of the draw...
Old 12-27-17, 10:22 AM
Mike728
Mike728's Avatar
Roland
You don't have to worry, as you would know by now if you had the issue.
Poppa (12-27-17)
Old 12-27-17, 03:57 PM
Poppa
Poppa's Avatar
Thanks Mike, I appreciate the quick reply.
Roland
Old 12-27-17, 05:36 PM
2013FSport
2013FSport's Avatar
Received 1,536 Likes on 1,278 Posts
For the vehicles being driven every 3 to 5 days it will not be obvious. However those who travel for example or have multiple vehicles, this will be evident upon sitting for two weeks.
I have the tools to measure the current draw while off. I could do this and do the math on the battery output but it would be be best if we had a Fixed or known repaired vehicle and a known bad vehicle to compare to.
In short with the engine off the ideal situation would be a current draw of say 0.0001 Amps or 1 micro amp. But that is likely not the case.
And if any 2IS 3IS owners find this, it applies to our car too.
https://www.clublexus.com/forums/att...sb-0035-16.pdf
Old 12-28-17, 06:58 AM
Mike728
Mike728's Avatar
Not entirely true. Mine was driven almost everyday, since purchase, until about March 2014. It sat 5 days in my garage and wouldn't start. Up until the TSB was applied, if I didn't leave a trickle charger hooked up, it would be hit or miss after 3 days of sitting.
Catalina45
10-04-18 08:17 AM
Mashie
Performance & Maintenance
07-12-09 11:29 AM
ArmyofOne
Maintenance
11-22-08 03:15 PM
itgrowsind
11-23-06 12:35 PM
RUDENESS
06-05-05 08:48 PM
Quick Reply: alternator death
