Battery choice
Okay guys, I would like you to chime in one way or the other. As I have said on other threads on this forum recently that I am about to put a new battery in my 2013 ES. In one of those threads I said I had toyed with the idea of an AGM but couldn't really justify the cost... so my decision was to go with another Interstate MTP-24F... that battery has 800 CCA's and 1000 CA's. well above the oem spec of 585 CA's. The warranty on the interstate is 30 months free replacement and pro-rated after that thru 72 months. The cost for the MTP-24F will run me about $130 to $150 or so plus tax... but then last night I stumble on an AGM battery that normally runs right at 200 bucks for $137.00 plus tax. It's made by Bosch and on sale at PepBoys. Unlike the interstates 30 month free replacement, the bosch agm is 48 month free replacement. True the specs on the Bosch aren't at high as the interstate, but they are still way above the specs that are on the oem panasonic battery.
![](https://static.pepboys.com/images/productImages/56564100/m/BOSCH-BATTERY-24F710BAGM.jpg)
$195.99
$137.19
With Promotion
![](https://static.pepboys.com/images/playbutton_prodlist.png)
Roland
$195.99
$137.19
With Promotion
Bosch Platinum Series AGM Battery Group, Size 24F
- Part #: 24F710BAGM
- SKU: 838890
- fitment notes
- ltd. 48 month free replace
- 48 month battery
- 710cca/850ca - reserve min = 120 - 60 ah - s6 high performance agm - oe cca: 585
- 710cca/850ca - reserve min = 120 agm - oe cca: 585
This part fits your 2013 LEXUS ES 350- Advanced, high-performance Bosch Platinum Absorbed Glass Mat (AGM) technology, designed to deliver up to 2X the life of conventional flooded batteries.
- State-of-the-art Bosch Platinum AGM delivers exceptional performance under even the most extreme hot and cold conditions.
Save 30% with Promo Code MMJ30
Roland
OK, Here's what the pros are saying: These are the 5 top rated in order of performance year of 2016.
1. Optima red top - 2. Optima Yellow top - 3. AC Delco Professional AGM - 4. Exide Edge professional sealed -5. Bosch Flat Plate Platinum AGM battery.
All considerably more expensive than a conventional battery and IMO absolutely not needed. Your cars were provided with a conventional battery from the manufacturer and IMO should be replaced with one. Other than the gateway fiasco where batteries were discharging, there were virtually NO issues with factory installed batteries from Toyota.
If I lived in the Yukon without a garage I'd consider these batteries. In the lower 48 they're just not necessary. Last night it was 10F here in PA and right now its 12F. All 3 cars started as normal... Mine is 5+ years old...Son's is 5+ years old so go figure...
BTW - The Bosch is $50.00 more than an Interstate from Costco even with a discount coupon so you're paying for the extra 18 months warranty......
Poppa (12-29-17)
Hello bc6152... thatnks for the reply - we don't have a costco store where I live and the Interstate Battery MTP-24F ( Not an agm ) sells for around $130 to $145 or so... So it is actually almost the exact same price as the Bosch AGM, which does provide an extra 18 months of free replacement warranty for essentially the same cost as the interstate wet cell. That's why I was asking what everyone's preference would be.. Interstate wet cell & Bosch agm = same price. Interstate has a little more juice, 800 CCA'S & 1000 CA'S compared to Bosch's 710 CCA & 850 CA's. so in a nutshell, yes you're right, it is an extra 18 months warranty but not for an additional 50 bucks, essentially the same price. However since putting up this threat I read somewhere that AGM batterys could develope problems if in extreme heat... well here I am in Louisiana, doesn't get much hotter than here, plus add in the additional heat from the engine compartment... so there's that to consider also. I'll do alittle more reading over the weekend and see what I come up with. In the meantime if any of you guys want to chime in, I'd love to hear what you think.
Roland
Roland
Hmmm. I guess I tend to think that Costco warehouses are all over and just about everywhere. Looks like I'm wrong about that. Too bad...
Good Luck with whatever you decide Roland.
Bob C.
Bob C.
I have used Bosch batteries before: both flooded kind and AGM. But I used them in BMW 3 series. Each lasted 8 years or so. You will be fine with Bosch. I have not used Bosch in ES. I used Interstate from Costco last month when the OEM battery in ES died after 3 years.
Poppa (12-29-17)
Bob.. you weren't wrong, you just didn't know.. I looked at the Costco Web Site and I think the closest one to me is around 170 miles west near Dallas... Please know I always appreciate your input and help when I post questions. I was a gear head long ago, but that was back when they still used carbureto's.... and when I could still crawl under a car.. LOL.. My problem is I overthink everything.. like the batteries.. I've got an interstate mtp-24f in my 4 runner right now... going on 3 or 4 years and no issues.. and that's probably what I'll put in the ES.. but when I saw that Bosch agm for the same money with a longer warranty, well I was the perverbial kid in a candy shop.. more more more... problem is I just don't know all the in's and out's of AGM's... Like I said, I read heat was bad for AGM's.. Hello Louisiana.. pretty warm here... also read AGM's are sensitive to over charging or charging too fast on the cars charging system.. stuff we never worried about 35 years ago.. The internet is not always a good thing... let's people like me find out waaaaay to much info..
Roland
Roland
Roland
Poppa (12-30-17)
Poppa (12-30-17)
Roland
Roland
My 2013 ES350 is four years old this month and the original Panasonic battery shows no signs of weakness, we have been in the teens at night and 20s during the day this past week.
You just missed $25 off Sam's AGM batteries, ended 12/25. I use Sam's AGMs in my boat and another vehicle.
The primary differences between the AGM and lead acid batteries is the ability to mount an AGM in any position and it's reserve and recharge capabilities. AGM batteries will take a deeper discharge and still be able to be recharged. They are good if you run your lights or stereos while the car is not running.
The one issue you need to watch is that not all cars have the ability to completely recharge an AGM battery. I ran one in my 4Runner as I had a lot of extra sound equipment, lighting, and a fridge and went on extended camping trips. The alternator never could completely recharge the battery when I ran it down, so I would throw it on a trickle charger every 6 weeks or so. That was the Odyssey AGM battery which is probably a better battery that any of the ones on the list above. But they are also nearly $300.
If I were replacing my battery I would get the Bosch as my fridge runs down the stock battery extremely quickly, and the AGM has the extra reserve capacity.
Otherwise I would hit Walmart or Sam's Club and pick up an Everstart battery with a 5 year warranty for under $100. (since there is no Costco near you)
Poppa (12-30-17)
Yes, Ratchey is correct. When I used Bosch AGM in BMW, I had to program into the ECU so that alternator will charge is correctly. It was easy to do using my laptop and bmw tool I have that plugs into the obd2 port. The same tool works on ES as well and I could see everything ECU was storing. The normal obd2 port reader is not sufficient and only provides emission related codes with no programming capability. However, I used the flooded battery in my ES recently, not the AGM.
Poppa (12-30-17)
Roland
Roland: I think you've narrowed it down to two very good choices. It's my opinion that you can't go wrong with either brand - Deka or Interstate. It just comes down to who has the best deal and longest warranty for your hard earned money. Good Luck with whatever you decide and since its 12-31-2017 I wish you a great 2018 full of health and happiness.
BC
BC
