2015 Lexus ES300 Dome Light
foot light 12v is not working, the led light is on but very dim i checked all the fuses didn't fine any fuse blow any ideas how i can fix it thank you
Since the led is on but dim, the circuit is complete. Maybe your battery is on its way out if you are also having starting issues. The LED may be on its way out too. It is easy to change and while you are at it, go for the newer and brighter LEDs. Most parts store will carry them.
nothing to do with the battery upon opening the door the 12v light should kick in on the foot light it's not doing that but light is on but very dim so i am not sure what is going on or what to check
danhtran
06-06-10 12:40 AM
