ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Door Edge Guards.
Old 04-18-18, 11:56 AM
nuraman00
nuraman00's Avatar
Default Door Edge Guards.
Can someone post a pic of a car with and without the door edge guards? I haven't been able to figure out how they look either with our without.
Old 04-18-18, 09:31 PM
Albo
Albo's Avatar
Door edge guards have been around forever. For any car. Just Google image it you'll find a ton. It's just a strip down the edge of your door
Old 04-19-18, 05:52 AM
bc6152
bc6152's Avatar
Received 1,306 Likes on 909 Posts
I don't like the look of edge guards. The color usually doesn't match anyway. Just be careful with the door...
Old 04-19-18, 12:30 PM
nodim2
nodim2's Avatar
I have the door edge guards on my 2018 Matador Red Mica, color matches perfectly, and you don't even notice them. Also have them on my wife's 2016 RX350 Matador Red Mica, same comments apply.
Old 04-20-18, 06:47 AM
Fillykonk
Fillykonk's Avatar
What Nodim said. I had to look twice after I had them installed to make sure they were really there. They are not the plastic obtrusions I was used to seeing on previous cars but a narrow film that runs along the door edge.
Old 04-20-18, 07:26 AM
nodim2
nodim2's Avatar
As a matter of clarification, mine are not a film, but a piece of flexible color coded hard plastic ~1/8" wide with an adhesive that attaches to the trailing edge of the door. If you weren't looking for it, you likely wouldn't notice it at all.
Old 04-20-18, 03:26 PM
nuraman00
nuraman00's Avatar
Ok, I understand better now. I had looked at images before, but I was looking at the door handle, and couldn't figure out what was different.
Now I see there's a little strip.
If anyone has them on their Lexus, can they take a pic? Just because it might get it from a better angle, than the pics I see on searches. Those pics are from the side of the car, while it might be easier to see the door is open and the pic is taken from behind. Or whatever someone thinks would be good.
Old 04-21-18, 06:12 AM
Fillykonk
Fillykonk's Avatar
Interesting. I took a second look at mine and its hard to determine whether it is hard plastic or a film. If the latter it is certainly thick enough to do the job. But like yours it is color-coded (Eminent White in my case) and virtually invisible.
Old 04-21-18, 06:34 AM
lesz
lesz's Avatar
Received 1,018 Likes on 696 Posts
The door edge guards on my 2017 ES are definitely a clear protective film. As I said in a different thread, I have no idea whether the car came out of the factory with them or whether they were added later by the dealer or as a port installed add-on. In any case, they are virtually invisible.
Old 04-22-18, 04:47 PM
nuraman00
nuraman00's Avatar
I think there's a difference between door edge guards, and door edge film.
As I noted in the Accessories between different models. thread, it seems that between the IS, ES, GS, and LS, some accessories are available on some models, but not others.
If you look at the IS accessories page, they have both Door Edge Film, and Door Edge Guards.
http://www.lexus.com/models/IS/accessories
So I think @lesz has the film, but @nodim2 has the guards. nodim2 described them as hard plastic.
I still don't think the picture of the guards on the accessories page is very good. So I'm wondering if someone can help and take a better picture, with perhaps a better angle, of them.
Old 05-26-18, 12:42 PM
nuraman00
nuraman00's Avatar
@lesz, just wondering if you saw that last post from last month. It seems there's a difference between Door Edge Guards, and Door Edge Film.
Old 05-28-18, 08:11 AM
john341
john341's Avatar
Yes they are different. Door Edge Guards are made out of metal and rubber and the Door Edge Film is made out of clear plastic or a clear wrap.
http://cdn2.bigcommerce.com/n-pktq5q...51.350.jpg?c=2
Old 05-30-18, 09:47 AM
nuraman00
nuraman00's Avatar
Thanks.
Can someone post a picture of the door edge guards? It's not clear to me, from the Lexus accessories page.
Old 05-30-18, 02:02 PM
jollick
jollick's Avatar
Thanks.
Old 05-30-18, 03:51 PM
nuraman00
nuraman00's Avatar
Thanks. Now I see the metal and rubber that was described.
Headsyl
04-21-17 05:41 AM
vinsonF
IS - 1st Gen (2001-2005)
05-03-15 03:29 PM
grottoman
12-23-13 04:24 PM
ahmed24
05-08-10 03:38 AM
Quick Reply: Door Edge Guards.
