ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Navigation screen splits in half?
Old 05-30-18, 07:19 PM
nuraman00
nuraman00's Avatar
Originally Posted by JDR76
Were you on the freeway when you tried this? Mine is always off unless I’m on the freeway. I had to turn it off while on the freeway.
I think I had also checked the map mode when I was on the freeway. But the next time this happens, and I'm on the freeway, I'll see again if it's de-selected or not.
Also, what color is the route trace? Is it the red dots? Is it something else?
Old 06-01-18, 07:23 PM
jollick
jollick's Avatar
Originally Posted by nuraman00
On my 2018 ES, it seems that when I'm on the freeway, the screen will sometimes split in half, vertically. And on the right hand side, it will tell me some info about upcoming exits (even if I'm not going to be taking them).
Sometimes, it will also have dining and ATM ($ icon) next to the upcoming exits.
What information is it trying to tell me? Can this setting be adjusted? I don't like having the map split in half. I'd rather see as much of the map as possible.
My 2013 ES didn't do this.
Go here https://drivers.lexus.com/t3Portal/d...f/OM06135U.pdf and look at page 82 and 113, see below.
Old 06-02-18, 08:01 AM
gamma742
gamma742's Avatar
Hey Guys... I know my car is old but on the new(er) ES, if you put it in the Map Mode / Map Only (not dual map) doesn't that stop ALL split screen behavior?
Old 06-08-18, 08:13 PM
nuraman00
nuraman00's Avatar
It didn't seem to stop it for me.
I'll have to see if the "Freeway Exit List" is somehow activated, the next time I'm on the freeway. It's been several weeks since I've been on the freeway.
The next time I am, I'll see if it's activated, and if I can tell it to do Map Mode only then.
I've had "Map Only" selected for a few months.
Old 06-09-18, 06:36 AM
lesz
lesz's Avatar
Received 1,013 Likes on 692 Posts
I don't do much of my driving on limited access highways, either, but, a couple of days ago, when I was driving on one, my curiosity led me to check the navigation menu. When you are actually on such a road, the "freeway exit list" is no longer grayed out, and, if you click on the "full screen" option when the "freeway exit list" is not grayed out, the list of exits will be removed from the map screen.
Old 06-11-18, 01:14 AM
nuraman00
nuraman00's Avatar
Thank you.
I happened to go on the freeway on Saturday, and noticed that the freeway exit list was no longer grayed out too. I then selected Full Screen, as you suggested.
Perhaps I will enable it if driving on a limited access freeway in the future. But for most of my driving, when I'm on the freeway, it's usually on a normal one with plenty of entry and exit points. I just wanted to have it off my default.
Thanks.
Old 06-11-18, 01:15 AM
nuraman00
nuraman00's Avatar
Any help? I'm not sure what I'm supposed to be looking at, to tell that the route trace is working.
Also, I usually have the map scale set to the 2nd to smallest one, which I think is 300 feet.
Old 06-11-18, 06:51 AM
JDR76
JDR76's Avatar
Received 1,612 Likes on 1,028 Posts
I don't use the route trace function, so it's been awhile, but I recall it leaving white dots on the path.
Old 06-11-18, 11:15 AM
lesz
lesz's Avatar
It lays down red dots. If you reverse the same route to get back to the place from which you started, it will lay down a second set of red dots in between the initial red dots.
mss1234
19
06-03-23 05:27 AM
cheld
08-11-20 08:57 AM
mss1234
15
08-02-16 01:19 AM
SlickRSM
06-22-09 07:07 AM
Dema
10-28-02 06:32 PM
Quick Reply: Navigation screen splits in half?
