Sorry to have been vague. Problem is I can't get rid of icons (restaurants mostly) all over my navigation screen. Every logical voice command I've tried fails to delete them. Need a tried and true command. Thanks, Phil-
While the list of available voice commands is significantly larger with the Generation 9 navigation system in your 2017 ES than it is with the Generation 7 or 8 navigation systems in the 2013-2016 ES, that list is still limited. You aren't carrying on a conversation with the car, and the system can only understand commands that it is programmed to understand.
As Mike suggested, it should only take seconds to use the system's menu to turn off points of interest that you don't want to appear or to disable them completely.
