Fuel Induction Service
When should I get my fuel system and intake valves cleaned?
It’s a good idea to take your vehicle to your trusted auto repair shop to see if it could benefit from a fuel system and intake valve cleaning if you notice the following:- Slower pickup when you step on your gas pedal
- Shaking or vibrating while your car is in idle
- Lower fuel efficiency
- A rougher ride than usual
Watch out for fuel induction services from the dealerships!
Sometimes the big dealerships will encourage you to get a fuel system cleaning as low as 30,000 miles. Make sure you refer to your vehicle’s owners manual to see what the manufacturer recommends, or find an independent auto repair shop to take a look at your engine for you if you have any questions or concerns. They will be able to tell you if there is enough carbon and deposit buildup in your engine to warrant getting the fuel induction service performed.To me it sounds like a dealer add-on to generate service sales. If none of the conditions above apply, I would pass and simply add a can of Chevron Techron fuel injector and valve cleaner for $12.99. Can't hurt... Use it on my 20 year old Corvette all the time...
PatrickAz (08-28-20)
I don't know that this car utilizes direct-injection fuel delivery (e.g. fuel delivery directly into combustion chamber), however my 2013 VW CC is this way and requires this kind of service when the symptoms mentioned in the previous post arise (from the VW forum, I see this is anywhere from 60k miles onward for the first service). The direct injection method does not have the benefit of fuel "washing" over the intake valve surface to keep the valve cleaner as with non-direct injection (e.g. port injection, etc), hence resulting in carbon build-up and other deposits that need to be removed with this type of service.
I drive a 2013 ES also w/ 90k on it. It's a cash grab by the dealer for sure, but doesn't mean it's not beneficial to your car. It's always a good idea to keep your fuel systems clean and lubricated, but not at the dealership cost. Nowadays most of the major brands of gas stations include some sort of fuel treatment in their gas (Exxon, Shell, Texaco, Chevron, etc.). But many don't. I buy the Lucas Fuel Treatment. One gallon of that is about $20-25 at Wal-Mart. I pour it into my gas tank at their recommended amount once a month during fill ups (I normally fill up weekly). Some people use it every time they fill up, others do it every 2-3 months. That gallon should last you a year or more, depending on how often you use it.
I’m with the other replies here as well. Just grab one of the bottles of fuel injector cleans, use as recommended, and be happy. The engine in your vehicle isn’t direct injection so shouldn’t need this service, not that it wouldn’t be beneficial at some point and mileage, just not this soon. I personally use Amsoil performance improver.
https://www.consumerreports.org/car-...h-extra-price/
https://www.toptiergas.com/licensedbrands/
st1800 (07-29-18)
Nope. You didn't say how your vehicle is performing but assuming it's running as it always has, that's just Lexus of Rockville or Silver Spring trying to gouge you. A little tip - if you want to get your vehicle serviced by the dealer, try taking your vehicle to a Toyota dealer...they do great work and tend to not try to sell you the extras that the L-dealerships do.
I agree with the earlier posts. Most gas additives are Techron or a variance of Techron made by and at the same refinery. Run Chevron gas and you get it for free. Or buy a bottle and add it to your fuel every six months.
Poppa (08-28-20)
Roland
As others have said using a top-tier gasoline such as Chevron, Texaco or Shell should be all you need to keep your car running clean. My use is predominantly Shell due to its plethora of locations in my area. On occasion I may have to run a tankful of Murphy or another off-brand but even then there is no noticeable difference in performance as long as it is only occasional. The cleaning offered by the dealer is only an attempt to pad its pockets.
Poppa (08-29-20)
dtapatia
RX - 4th Gen (2016-2022)
30
06-18-20 07:50 PM
Timothyj
06-05-14 03:53 PM
Topshelf
RX - 1st Gen (1999-2003)
08-31-07 11:48 AM
