ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
ES350 - 87 Octane or 91 Octane???
Old 01-27-19, 11:27 PM
  #46
AnantD
AnantD's Avatar
You really need 140 plus hp at the wheels with a ES size car to have adequate response in the mountains. You can get this with a 260 plus hp car or a 230 hp turbo car. Anything less is going to strain to keep up in traffic in the Colorado mountains. I lived in Colorado for many years so I know a little bit about this. The ESH is going to be 120-150 hp in the mountains, depending on altitude. Evergreen is at around 7000 ft or more on 285
Old 01-27-19, 11:35 PM
  #47
AnantD
AnantD's Avatar
Tesla’s are electric only and not hybrids and would be excellent in the mountains. You could regen a lot of lost energy on the down hill grades.
Their total power is unaffected by altitude.
Thats why the regular ES with its 268 to 302 hp V6 does fine though you do feel the loss of power.
Old 01-03-23, 07:24 PM
  #48
User 122922
User 122922's Avatar
Originally Posted by actright
After picking up the ES350 before I left the lot, the salesman told me that the ES motor was designed for 87 Octane, I had an 02' Acura TL and always used 91 octane. I feel like 91 runs better on V6's, Wanted to see what other users recommend for gas on a daily commuter.
I just got an 19 ES 350 f sport very confused which fuel I should use 87 or 91 ? And if it is 87 do I run in problem If I use the 91 other than my wallet !?? Thanks
Old 01-03-23, 10:30 PM
  #49
st1800
st1800's Avatar
Please, just check your owners manual. It will specify what’s correct.
Old 01-04-23, 03:31 PM
  #50
Kijug
Kijug's Avatar
Yes, check your owner's manual. I don't know about the F Sport, but normal ES 350s (mine is a 2014) use 87 octane. Using higher octane won't hurt your car, just your wallet. That said, going lower can hurt your engine over time (i.e., going lower when "performance engines" desire a high octane).
The octane affects how "compressed" the gas needs to be before the spark plug ignites. Using the correct octane is timed correctly with the spark plug timing. Technically, if you change octane from the recommended, you should alter your spark plug timing. You're not getting any benefit from going "higher" in octane and you'll only cause "knock" if you go lower (eventually causing problems).
I love the ES 350 because it has a good-enough ooomph for me but uses only inexpensive 87 octane. My previous 2003 Acura TL Type-S had about the same performance but used 91 octane at +$0.40/gal more. Ug. Now my son has to deal with that since he has the Acura now. LOL!
Old 01-06-23, 02:28 PM
  #51
jgscott
jgscott's Avatar
Received 1,369 Likes on 1,085 Posts
Just a FYI. Without pointing to any one post, there is a slew of misinformation here about this topic, and what would and would not happen. Most other Lexus Model Forums here know about this. Seems the 4th Gen GS, and the ES Forums are not as aware. There are very experienced Tuners who have spent 1000's of hours on the newest Lexus ECU's. From the Stock Baseline maps to changes, to get peak efficiency maps. The Data is the Data.
Start to research Lexus ECU KCLV and more.
Old 03-24-24, 11:07 PM
  #52
ArthurFW
10th Gear
ArthurFW's Avatar
Default Octane, altitude and compression ratio
Remember, the higher the elevation above sea level the less your engine can "make use of" the fuel's octane rating. In other words, the octane rating number requirement decreases with altitude.
The ES 350's compression ratio means the engine has been tuned and spec'd to use 87 octane fuel at sea level (where atmospheric pressure is highest). Using a higher octane fuel is utterly pointless and a gratuitous waste of money. It's just as pointless using higher octane fuel at higher altitudes.
Colorado has 85 octane fuel because of its typically higher elevation above sea level.
autotech13 (03-25-24)
Old 03-25-24, 09:09 AM
  #53
Tootsall
Tootsall's Avatar
I found this YouTube video that pretty much shows how marginal the power increase might be as you go to progressively higher octane ratings. The only fuel that showed any significant power increase was the E85 but, if you wait until near the end of the video, they explain that it requires up to 30% more fuel flow to achieve that! (hardly an economical choice).
Here's the link
If you don't want to be bothered with watching the video, here's the comparison chart: you'll note that this is with an engine producing twice the power that our 3500 V-6 does. If, however, you've made up your mind that if you are paying more you must be getting some benefit then...that's your choice. I'll go with science and real life testing.
Old 03-26-24, 06:11 AM
  #54
autotech13
autotech13's Avatar
Reading the owners manual is quite informing in telling you what octane to use!
Old 03-26-24, 05:54 PM
  #55
jgscott
jgscott's Avatar
Here's the link https://www.youtube.com/watch?v=ryqyTPfNj1Q&t=605s
LOL! On a American LS V8 engine? Don't know what the Timing is set at, don't know what compression the hand built motor is running? That it is on a stand. No temp changes, No load, no air changes. Then no time and miles for the ECU to adjust, and not a Lexus ECU with KCLV mapping. Ok.
Old 03-27-24, 01:08 AM
  #56
rmak
rmak's Avatar
I will just say what works for me. I run regular 87 in both of my trucks (5.3). I use a mixture of marvel mystery oil and marine stabil every few tanks to lessen the effects of ethanol and keep the fuel pump and top end lubricated.
In my ES 350 and 4Runner I run premium. I use the same mixture in every few tanks for the same reason, being careful not to use too much as to set off any codes. The premium fuel in both of these vehicles makes a notable difference in performance (power and gas mileage).
When I switched to premium on the ES 350 I first unhooked the battery, replaced the MAF sensor, air filter and pcv valve. I then hooked the battery back up and started driving. I noticed a small change right away. Another reason for running premium for me is to keep carbon deposits down on the valves and top of the pistons. On previous engine tear downs, you can tell right away a properly tuned and good running engine from others just looking at the top of the piston.
Old 03-27-24, 06:04 AM
  #57
autotech13
autotech13's Avatar
If you want to keep carbon deposits down, use Top Tier gas.
rmak (03-27-24)
Old 03-27-24, 09:48 PM
  #58
shoodes
shoodes's Avatar
Been so many comments on here and this is always a crazy topic full of psuedo-science and people arguing this and arguing that.
I just use whatever the manufacturer says.
Also much prefer top tier gas if I can.
If it says use 87, use 87. Sometimes I like to put 93 in there because it makes me feel better. I also use techron after every oil change because it makes me feel better. I don't notice a gas mileage difference on 93.
if it says use 93, use 93.
My mom drives a 2022 Genesis GV70 with the 3.5L Twin-Turbo. Requires premium. It's my mom's vehicle, but my dad or myself usually fill the gas in it. I drive it around (pretty fun to drive actually!) pretty frequently.. I noticed that when she got gas for the first time it felt slower, then a week later she complained that her MPG dropped by 1-2. I asked her and she filled 87. However, Hyundai states that it needs 91/93 for optimal performance and 87 is "acceptable".
amf1932
ES - 5th Gen (2007-2012)
196
05-17-22 08:26 AM
billm555
ES - 7th Gen (2019-present)
10-27-18 07:29 AM
gemini6kl
15
04-18-15 08:39 PM
Timothyj
13
05-26-12 07:00 AM
Antphilli
05-05-08 12:58 PM
Quick Reply: ES350 - 87 Octane or 91 Octane???
