Commenting on suggested maintenance items for 90k miles
I couldn't service my car at the usual mechanic and took it to the usual Toyota dealer which is next to my house. They suggested to do these things for my 2013 ES350 with 90,500 miles. Can you guys comment on these items? This particular service advisor also commented on the transmission fluid which I was shocked!
1. Replace serpentine drive belt - they said they found belt "glazed"
2. Clear air induction system/throttle body - this seems like BS to me
3. Replace coolant (isn't this done at 105k on Lexus?)
4. Clearn fuel injection system (another BS item?)
5. Replace transmission fluid at 100k even though it's "lifetime" (First Toyota/Lexus service advisor who has said this since I bought the car new 6 years ago!)
At 90,000 miles you need the brake fluid changed, oil changed and tire rotation. These done ala carte should be around $210. The air and cabin filters you can do in five minutes for both and both cost $20 each on line. The service manager's at Johnson Lexus Raleigh and Durham both told me do not change the transmission fluid. One of them has 25 years experience working on Lexus vehicles and has been trained by Lexus. He said it never needs to be changed. He went to Detroit where the transmissions are made for training and asked what is the #1 cause of Lexus transmission failing. Their reply was the wrong level of fluid and the wrong fluid. Both factors in changing the fluid.
I forgot you were in NC also. Yeah, for 90k - I only did oil change, tire rotation and brake fluid change but went to Hendrick Toyota in Apex since I am so low on time and I live right there. I do cabin and engine air filters myself. Usually, I take my car to WASP auto in Durham, who are very honest mechanics. Johnson Lexus has always told me NO to the transmission fluid change.
Tootsall (03-14-19)
i would replace the spark plugs, brake fluid, coolant, serpentine belt, atf if it has not been changed yet. those are fairly basic to a home mechanic. i'm pretty sure the throttle body cleaner and fuel system cleaner are bottles from the parts department that will be used for the service. the fuel system cleaner will be poured into the gas tank and the throttle body cleaner will be sprayed while car running until empty. just my assumption.
If indeed that is what your dealer does, I suggest you get a new dealer.
My independent used to remove the Throttle Body to clean it and used a machine to clean the injectors. Of course he was an honest mechanic.
Here is what a typical high quality shop does.
https://tomdwyer.com/2014/uncategori...uel-injectors/
I would expect no less from a dealer shop. ESPECIALLY a Lexus Dealer!
So I took this to a very dependable Japanese mechanic and he said DO NOT clean the throttle body and that they are trying to scare me by saying the serpentine drive belt is "glazed." They say it does not need replacement. Only thing he recommended was a coolant change at 100k.
gfaile
30
02-20-14 04:27 PM
