Audible Text Notifications
Not sure what’s going on but on my iPhone this ? Is not there - there is an “i” in a circle and when I tap that it only shows choices regarding importing of contacts, nothing on notifications.
My iPhone has the switch to show notifications under the “i” just as alexNY suggested under the ? on his iPhone. I would suggest we might be dealing with different versions of Apple IOS or different versions of Bluetooth (I.e. different age of phones)? For the purpose of comparison, I am using iPhone Xs and IOS 12.2.
So when you select <Settings> <Bluetooth> and turn Bluetooth ON, then click on the circled "i" for the appropriate "My Devices" item for the car, it does not look like this: ? (I'm on IOS 12.2 also). If you haven't changed the "name" of your Bluetooth on the car itself you will not see "Lexus" but it will be called something like "car audio" or "mobile audio" or some such. That should be which Bluetooth is showing as "connected" on your phone if you are in the car with the accessory power ON.
Mine looks exactly like this, except without the disconnect since I’m not currently sitting in the car.
If I were you, I might try removing and reconnect in your phone’s Bluetooth settings.
I wonder if your bluetooth somehow got corrupted on the phone? Does your bluetooth music play ok? Other than that perhaps it is something unique to 7plus.
Certainly it sounds like an issue with the phone rather than Nav. I would find a technology specialist at the dealership; they are used to these issues.
