2013 es350 99xxx making weird noises from engine
Can anybody help me letting me know if this is normal car sounds like a loud rattling noise as if something is loose while it’s running not just on a cold start up also I threw water on it nothing leaks
From the sound, my guess would be water pump bearings going bad. If you are handy with tools, pull off the serpentine belt and see if the rattle stops. Caution -Do not run the engine for more than a minute or 2 without the belt.
Idler/tension pulley bearings or the WP.
2013 ES350 64K miles. Recently noticed engine chirping on passenger side when cold start. Stops after 1-2 miles of driving. Did the "water test" and noise immediately stopped! Think I have an annoying serpentine belt that may be wearing out. Noise just started so I'm not too worried at the moment. However, about to drive car from northeast to Florida this weekend. Would you recommend I get the belt replaced ASAP or wait until I get back to FL?
Videos here
http://bit.ly/31AKn6k
http://bit.ly/2z1uPfL
Videos here
One HoT
Performance & Maintenance
15
06-11-03 12:32 AM
