Are headlights truly not adjustable?
I bought a used 2015 ES300H with HID headlights. The right headlight was aiming too low, so I took it to the dealer, who informed me that the headlights are not adjustable. I found it hard to believe so I did a little research. I found that there are some wheels that you can rotate with a philips head screw driver. I played with them but no matter how much I turn them in either direction, the headlights don't change. I also tried turning the 9mm screw, no joy.
Was the dealer right or am I doing something wrong?
I have a 2015 ES350 with HID headlights and i actually adjusted mine last night. I raised them a little bit and it made a huge difference as they are aimed too low from factory.
Here is a helpful post
https://www.clublexus.com/forums/es-...too-low-2.html
The dealer also refused to fix the blind spot monitor under warranty because the car had been in an accident and he said that it needed very delicate adjustment!
If the collision damage was to areas where one or both of the BSM radar units are located, then you should return your vehicle to the collision repair facility to have the BSM alignment done since it would not be covered under your Lexus warranty. Your situation doesn't seem any different than when we had to have the front PCS/DRCC radar unit on one of our vehicles aligned after a very minor collision - it was done by the collision repair facility.
If you have auto-levelling headlights the sensor may be damaged and sending a wrong level to the lights so that the mechanical adjustment is maxed out?
I'm not certain whether the self-leveling headlights can actually be adjusted. I've been told by the service advisors at two Lexus dealers and one Toyota dealer that they cannot be adjusted. Essentially what they have said is that any attempt to adjust them will result in a change in the starting positioning of the beam, but that, once the leveling process has completed, the beam will end up in the same level position.
I’m thinking of bent or broken components around the sensing unit in rear suspension. I think there’s a thread here somewhere about a mod to the mount for that sensor.
I had seen that post and I found the adjusting wheel. I turned it but I didn't see any difference. Since the dealer had told me that they could not be adjusted, I quit. Now I will try again, turning it more. I will put a drop of nail polish on the metal wheel to be able to count the turns. I will let you know!
The strange thing is that the good one has a yelloish nut with a slot, while the bad gear has a black nut (9mm) with no slot.
Mi guess now is that one of them was replaced and something is wrong with the black one... I think that I am giving up, because I am guessing a light assembly is probably close to $1000 and a ***** to replace!
Maybe not...check out some of the recycled parts places.
I placed a dot of paint on the metal gear and noticed that it seems stuck! I triy to turn it it moves a few degrees but then it jumps back to the initial position. I then tried the same thing on the other one, and that one turns ok!
If you can get techstream from ebay. There is a test that can check the auto leveling system of the headlights. You can move them up or down with a computer. I'd check that.
