noise from brakes
hi guys
i am having something that is really anoying and also worrying maybe something is wrong or maybe it is just common for the vehicle to do since its a hybrid and it has to do with braking perhaps.
The thing i am noticing it gets more and moreover the past few weeks
but there is a squeaking sound almost like a squeegee going across a dry class services of when you walk with shoes and slide the sole against a polished floor and get a squeaky noise it's not happening especially when breaking its at slower speeds it could be when coming to a stop and also when lightly lifting up on the brakes to move and then braking again it used to happen once in a while now it happens a lot more often is this sound familiar anyone have this issue happen?
Thank you
Thank you
9 mm in the back and that was only 4000 miles ago but I have noticed that this car has made this type of annoys her about the past 40,000 miles but it was usually just once in a while now it’s getting more often so that’s why I was thinking I’m wondering if it’s because of some components due to the hybrid braking system
I am making this post from my phone which doesn’t do great at punctuation and grammar and spell Chuck I apologize because I know some people really think that it’s bad and that I’m not a great person I guess or don’t reply because they see that I can’t spell so they automatically assume I’m lazy I will go through and edit it once I get home on my computer later today or tonight
thank you
Remember, on a hybrid the actual mechanical brakes only engage when you press hard on the petal or at the last few moments before a full stop. When you brake normally (gently), the motor generator is engaging. With that in mind, I doubt it is the brakes that you are hearing. Hybrids typically have a little bit of a whine even when you aren't braking, although I can't hear it unless the windows are down at low speeds (or one drives by when I am walking). My wife and I virtually never drive with the windows down so we don't ever hear it. That mild whine should not be loud or very pronounced though so if you are hearing it inside the car with the windows up and/or any music playing, I would definitely have it checked out - especially if you think the sound is getting louder.
I just went online made an appointment for my dealership this week to look at it cause I can hear it with the music on and windows closed
also soemtimes when I’m at a complete stop not all the time but soemtimes if I double pump or lift off really lift up the. Back down so just bump the brakes I hear this noise but it is not the noise when you hear air that’s not it it’s a louder noise like when you slide rubber sole shoes on Presley waxed floor time of Squeegee noise almost
Now I wish tomorrow came sooner cause this noise just got more weird like I put my foot on the break held the break down shifted from part to drive without moving the brake peddle pressure was still pressed down same pressure and this noise appeared during the shifting
and it is coming from the driver footwell area that I’m positive off
Pretty sure that's just really clean (not really dirty) brake rotors scrubbing against the pads. like if it recently rained or something. honestly its nothing to worry about if its just a rapid grab/release sensation like when you stop or release the brake as the car moves forward. just drive it a while it'll go away.
dealership was not able to reproduce but about 20 minutes after I left started doing it
and today it did it after I stoped like I stoped at a red light at about 5 seconds after complete stop it happened
08-27-15 06:18 AM
