Lower gear to slow down the car instead of using brake?
Hello folks, Let's say I want to slow the car without grinding brake pad...So I just lower the gear.
Will that damage my engine ?
As much as I like to "downshift" myself, having owned many manual transmission cars, and not knowing the true consequences of doing so on this transmission, I've decided brake pads are cheaper than a transmission to replace if you catch my drift. I'll use a low gear when in stop-and-go traffic and the GPS tells me traffic is thick for miles and miles ahead. That's when the engine braking effect comes in handy over and over again.
PatrickAz (04-07-20)
The only time I downshift my '14 ES 350 is in mountain driving to prevent overheating the brakes on steep downhill grades. No apparent engine or transmission damage in 72k miles. Original brake pads still good at last service at Lexus.
PatrickAz (04-19-20)
jamestpc (04-09-20)
Our Priuses had a specific position on the gear shift for engine braking so I am assuming this "engine braking" philosophy is still accurate with our Lexus hybrids, even though they have a more conventional gear shift lever/indicator.
Just some food for thought...
The car will prevent you from downshifting to a gear that would put engine RPMs too high and the transmission in peril and will sound an audible tone as if to say "Don't think so!"
TechNut (04-08-20)
You can, safely for sure, but I thought brake pads were cheaper then powertrain components?
so I had a Prius before ES350. I always use the Prius B gear to slow down the car instead of braking lol It won't damage Engine as they claim. But I Just want to make sure it won't damage ES350 lol
I have a scangauge 2 installed in mine and it has transmission temperature. If you could see how the temps rise by doing this you would be surprised. Even mildly spirited driving will push the temp over 200 degrees. I think the idea behind downshifting to aid braking on hills and mountains is so the brakes do not overheat and fail. Trucks use this for heavy loads and very steep grades. I will do it occasionally in my trucks when towing.
IMHO unless it is rarely used for safety I would not do it. The engine will be fine, the trans will get hot.
i drive in the mountains and the only time i have used a lower gear in the Hybrid is when going down a step hill on the mountain road i will put it into 4th soemtimes shift it into 3rd for engine braking
but wondeirng how about using manual mode to shift to safeon brake pads also
I wouldn't do it in normal driving, no. When driving in the mountains and trying to combat brake fading thats another story.
I've done it before in my previous car, only on a few occasions where it was snowing and I was going less then 30 miles per hour. My tires were all-season and I wanted the extra assurance that my car wouldn't accelerate drifting down a hill and braking would cause sliding. It's probably OK under slow speeds and rare occasions.
