Lowered - alignment oddity
So I have camry springs, as do many others, installed in my car (H&R). I took it for an alignment today and the guy notes that only the left side (I guess it depends on which order your springs are installed?) is out of camber. The right side is fine. There is no adjustment for camber on our cars unless you change out the control arms.
Wondering if anyone else has noted this?
Thanks...
Thanks...
Lowering a car with no other changes will result in negative camber. Not sure why the left side is only showing negative, sounds strange to me. Should be both. 1 degree of negative is not bad and can actually help handling. You can sometimes adjust the toe to counter the tire wear of negative camber a little bit.
If the springs have recently been installed, did the installer re-clock the bushings? This is when you loosen the bolts for the a-arm bushings/control arms etc. so that they can move without binding as the car is lowered. Then after setting the car down and settling the weight you tighten them back up. Some bushings are stuck and when lowered the bushing rubber will distort/tear. This can also result in uneven stance. Just a thought.
It could also be the alignment equipment / technician. As I said, very weird for only one side to be off.
Just trying to give you ideas. Does the car sit uneven?
I think its been 2 years now its been dropped. I've done alignments twice i think? I had a shop install the springs for me (have used shop on lowering my other cars too).
Doesn't sit oddly at all to be honest. I'm fairly handy when it comes to wrenching so i'm not worried about that. I was hoping the other lowered es guys would chime in if they had the same issue.
