Lexus ES350 driver side DRL not working
Hi All, I have 2013 Es350 and my driver side daytime running light is not working. Any idea what is the fuse for the same ? Also, any wire connection I can check. My battery is almost 7 years old and will be changed soon. Can it be connected ? Passenger side DRL is working but I had to jump start my vehicle couple of times recently.
Here is a link to the fuse diagram:
https://www.carknowledge.info/lexus-...e-box-diagram/
I would change the battery first, as from my experience, modern luxury cars start acting funny when the batteries are on their last leg.
Thanks a lot for your response and will change the battery asap. However, I did not see any mention of DRL or daytime running light in the fuse box link that you shared. Any idea whether it will be under a different name ?
After that I would go through and check the electrical connection for the drl first and if that was good just accept that I might have a bad drl and replace it.
That would be my steps, for what it's worth.
Edit: should be fuse's 33 and 34
sinstrex
12-23-13 12:02 AM
