Noob Question: Does the 2016 ES350 have a Battery Warning Light?
Does the 2016 ES350 have a Battery Warning Light? If so, can someone please point me to a diagram of it in the manual, or a picture of it in action?
Thanks.
MotionMan
Thanks.
MotionMan
Not sure what your question is about, but there is no specific "Battery Warning Light" on any ES350 models. There is a charging system light which shows the overall charging system operation that basically tells you if the alternator is charging the battery properly or not. That dash light is the red battery shaped symbol with + and - marks inside it. It should be illuminated along with all the other dash warning lights if you switch the ignition on without starting the car. If that light is ON when the engine is running, it does not necessarily mean your battery needs replacing but there is something not working properly.
Hope it helps.
Hope it helps.
Hope it helps.
Hope it helps.
Thanks.
MotionMan
