2016 ES side mirror cover replacement
I need to replace the mirror cover on the pass side. I've seen some UTube videos that show people pulling the bottom of the mirror glass out and down to remove the mirror. This allows access to the screws holding the cover in place. I haven't seen any videos on how to remove the glass on newer models. I tried to pull but not too hard. Didn't come loose and I 'm afraid I'll break the $300+ glass. Can anyone confirm how to remove the mirror glass? From what I can see the back of the glass looks different from the older mirrors. I can see the screws for the cover so the mirror glass has to come out somehow. Thanks
Pete
Pete
Answered my own question In case anyone else needs to know, you just pull on the mirror glass and it pops off. Different from earlier years. Do not pull out and up, just out. There are 4 plastic clips that are attached to the rotating back part.
lji (03-29-21)
I have 2014 , same problem
Looks like they insert a cloth in under the mirror glass from side to side and pull up and then out. I’m not having much luck, and as you say, afraid to break the glass ...,
I’m not much help, but hoping for a response as you are.
Walt
Walt
Removing mirror glass
Pete:
just saw your 2nd post about just pulling out on mirror glass - I can’t get my fingers in around the mirror to pull it out. Are you prying it out with screwdrivers or something ? I tried prying and pulling but still afraid to break the mirror with too much pressure. Nothing seems to be budging when I pull.....,
Walt
Walt
Pete:
Walt
Walt
mirror follow up
Pete:
Walt
Walt
Unfortunately mirror still doesn’t move or even make a sound when I press the buttons. This all started when my wife clipped the garage on her way out. That broke up the plastic frame that surrounds the mirror. I was hoping to find a broken wire inside, but all innards looked ok. Guess I’ll need the $900+ new mirror fix now.
Walt
Another thread for this topic here.
A similar thing happened to mine as well, but the side mirror motor works fine. It might be the motor behind the mirror that's damaged and you could possibly try to get the existing motor fixed. Entire side mirror assemblies look to be between $350 - $500 depending on if the vehicle is optioned with blind-spot and/or memory package. The replacement of the entire side mirror assemblies looks to involve taking the interior door panel off, but not bad for a Saturday morning job. Else, see if a trusted, local mechanic will be able to put this on and buy the part yourself.
YouTube link showing how to fix/adjust mirror motor (older gen):
Thanks again, Pete. With mirror tilted up, I used a towel in and around the bottom half of the mirror, and just yanked outward and up. It popped right off.
Walt
Walt
gagrown
GX - 2nd Gen (2010-2023)
17
02-17-21 11:48 PM
