View Poll Results: How are 19 in rims with 225/40/19 tires ride
19 inch rims aren't the way to go
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
0%
18 inch rims are better way to go
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
0%
19 inch wheels will rub without changing suspension
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
0%
19 inch rims are perfect and comfortable ride
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Does anyone have 19 in rims on
Clearance can depend on the width and offset. Tire size, I'd recommend a 245/40-19. The 225/40-19 would yield too short of a sidewall. I know the factory f-sport is 225/45-18, but that's undersized when compared to the base. Matching overall diameters, a 235/45-18 is as close as you can get to the base 215/55-17. Personally, I went with a 245/45-18 on 18 X 8 wheels. I wanted a little more width and cushion. I run on stock suspension with zero clearance issues. The added width looks so much better and truly does wonders for grip.
Bucjuice (03-24-21)
Use this site. Put original info in left side and change rim/tire in right to see effects.
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
Bucjuice (03-24-21)
^^^what he said.
