Dome Lights, Moonroof not working
Suddenly, the dome lights, map lights, vanity lights and moonroof are not working. I checked the fuses but they don’t seem to be blown. Can they still be blown if they appear not to be? Any other suggestions on why these things aren’t working?
“I checked the fuses but they don’t seem to be blown. Can they still be blown if they appear not to be?”
yes, they could “look” OK, but not really. Pull out and reinsert the suspect fuses. Could be just some corrosion. While you have them out, take a very close look at them, they can burn out in places that are not readily visible. Or simpler yet, just replace them.
Or, to be 100% positive, if you have a volt meter check continuity across the fuse because as st1800 stated the fuse could look good and be blown...
Yes, I ended up replacing the fuses. However, some of the interior lights are working such as the footwell lights and the console lights. The others like the vanity lights, ornament lights, door lights and map lights are not working as well as the moon roof. Idk
Scalene
12-20-11 09:55 PM
