Replacing Oxygen Sensors
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
The engine light on my 2016 ES350 came on. So I took it in to the dealership to find out what was the issue. They came back with the Oxygen Sensor Bank 2, Sensor 2 was needing to be replaced. They wanted around $750 to replace it. I am fairly handy wanted to but the parts and replace it my self but am having a hard time finding a diagram of the oxygen sensors for this generation of ES's. Any idea as to where I can find a diagram for the 6th generation of Lexus ES350?
Thanks in advance.
Thanks in advance.
Do you know the codes that came up? That's a pretty steep price. If you do need it replaced, at least the downstream sensor is a lot cheaper than sensor 1. It is not too hard a job if you can get under the car, although some can be difficult to break loose. This might help.
https://www.clublexus.com/forums/es-...-es-350-a.html
Just a thought, that could be the rear bank (i.e., firewall side), and everything over there is *itch to get to ...
My karma just ran over your dogma
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (it's aubergine)
