CV Axle
>I really believe the dealer knows exactly what’s wrong
Why not take it to your local Toyota dealer? They might be very happy to perform the repair and charge Lexus for the warranty ...
My karma just ran over your dogma
Current Hers: '13 Lexus ES350
Current Mine: '15 Jaguar XF (it's aubergine)
Tootsall (10-21-22)
JgScott thanks for all that information.I really believe the dealer knows exactly what’s wrong and is not being truthful,being a female makes it worse.I plan on taking it to an independent mechanic although I feel Lexus should be honest and make the repair since it it under warranty. I’am really at wits end over this whole situation I also plan on calling Lexus corporate to make a complaint. The dealer informed me that they changed the axle to see if it would work and “ claimed” it did not and put back my old Axlebecause” Lexus will not pay for it if that’s not the problem”....I say bull**** thanks for your reply.
Go back to the Dealer. Is it a Lexus Dealer? Ask them: so you put in a new Axel right? Still clicking right? So then that tells you, that you determined it was that side and Axel related. So if the Axel did not correct it, then it has to be the Transmission, that contain the differential that the Drive Axel gears fit into that turns the drive Axel. That's how the ES350 FWD works. BTW again is it a Lexus Dealer? And is there anymore missing to the story like the car was in a accident, or some other place has repaired, damaged or worked on it before? What year ES350? How many miles?
While it may indeed be a problem with the axle, there are a couple of other areas to look at.
There are a few of issues I have experienced with my 2004 Civic, 2005 Corolla, and 2016 ES350. Years back I before I sold it the Civic had an occasional clunk in the drivers front. I replaced the axle on the Civic thinking it would fix it. The noise persisted, and closer examination with power braking showed I had some play in the axle to wheel bearing junction. This past year the Corolla developed the same issue. I figure just replacing the axle as I did on the Civic will not help, as the splines in the wheel bearing probably are a bit damaged also. I will probably replace the axle and bearing to have good spline contact.
The ES is another story. I have another posted in a thread on this. https://www.clublexus.com/forums/hyb...ers-noise.html
The clunk is from the design of the brakes and in my case greatly reduced after freeing up and greasing the slider pins and pad to clips surface.
Also, check your sway links. That's one of the first suspension parts to wear out. My ES has around 78k miles, I just replaced them, they were completely shot. Car has had an easy life of smooth roads. Probably should have been changed years ago. Didn't solve my rattling noise though.
If your car is under a factory warranty, just take it to another Lexus dealer and let them diagnose. Dealerships in general are very dismissive in my experience about noise complaints when it comes to warranty repairs. But if you're paying for the repair, they have no problem shotgunning thousands in repairs to try and fix it.
Good point on the drop links for the sway bar, as I have seen quite a few cars in my friends shop over the years with play in the bushings clicking over bumps. I have had a couple clunking issues on other cars with worn ball joints and drop links.
Lots of people choose not to replace cracked boots which will eventually open allowing dirt and gravel entry that takes out the joint, inner boots rarely split unless you have very cold winters because they don't flex like the outers.
You cannot confuse cv joint noise with any other noise once you've heard it.
You can also get half shafts without the inner joint.
