Issue initializing TPMS
#46
The IDs are correct. The car just fails when it tries to figure out location of each sensor. It does not display pressures at all because it does not know where to show them on the diagram.
By the way, in 2013 localization was only implemented on Lexuses. Toyotas would just have a single TPMS light with no reporting of individual pressures in the dash.
#48
#49
Mine is '14 and it displays dashes with 4 Autel MX-sensors. Whether the cloned sensors get localized or not most likely depends on the sensors. Autel is constantly revising their sensors. I have it installed in four cars so far. It used to support only one single frequency - now it support both frequencies. It used to be metal stem only - now a rubber stem is available. The shape of the sensor also has changed over the years.
#50
I just had a discussion with the supervisor at the tire shop where I got mine done. He tells me that as of 3, 4 years ago, Autel started producing sensors that were "dual frequency" (433 and 333 Mhz) and that when they clone them the frequency gets set to match that of the original as well as the ID#. He said that their shop just buys Autel "MX" sensors. I don't know if that helps or not but there it is.
(I think he meant 315 Mhz).
https://support.autel.com/support/so...ers/8000083697
#51
#52
Yeah, but Tootsall has all four Autel MX-Sensors and localizationn is working for him. I once had a combination of 1 oem and 3 Autel sensors with localization also working.
