ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Continuous or phantom battery drains on our cars?
Old 01-25-16, 02:51 PM
Universe93
Universe93's Avatar
Default Continuous or phantom battery drains on our cars?
My ES sits outside at various times in very cold weather. I tried searching, but had a question on what kinds of things constantly drain the battery even with the car just sitting there with no interior lights on.
Modern cars these days seem to have lots of electronic gadgets. Even opening the door with the key in your pocket starts up the screen that displays the mileage.
I did notice that after several hours or in the middle of the night, the Lexus ES has a fuel evaporation leakage check that makes a "buzzing sound" for several minutes. That is normal, but of course uses some battery power.
Any other issues or continuous battery drains we have on our cars?
Old 01-25-16, 04:45 PM
jollick
jollick's Avatar
I would not worry about it unless you are storing the car for an extended period of time. If you do, use one of the battery tenders available. My wife's 2015 ES350 sits for 2 to 3 weeks at a time and has not had an issue. Her 2006 GS300 would also sit for 2 to 3 weeks and no issues, the battery lasted for 9 years before we replaced it.
Old 01-26-16, 03:06 AM
Halfmoon
Halfmoon's Avatar
Default Battery has completely drained twice
https://www.clublexus.com/forums/es-...ain-issue.html
Old 01-26-16, 05:06 AM
Mike728
Mike728's Avatar
I think she's in the minority. From what I've read in the other threads, most, including mine, can't make it much past a week. And, this is in the garage. I've learned to go the battery tender route, as you mentioned. All is well, now.
Old 01-26-16, 06:24 AM
Maikerusan
Maikerusan's Avatar
Our sits several weeks at a time, and the garage is very cold in winter. Never an issue.
Old 01-26-16, 06:35 AM
bc6152
bc6152's Avatar
Received 1,300 Likes on 905 Posts
The longest my car has gone is 5 weeks - outside - and started immediately. Not even sluggish...
Old 01-26-16, 06:53 AM
Mike728
Mike728's Avatar
You people annoy me!!! j/k
Maybe I should have it looked into?
Old 01-26-16, 07:02 AM
mspearl95
mspearl95's Avatar
have you thought about the seat extender drain prob? mine has also sat for almost a month(only once) in winter, and started right up.
bc6152
bc6152's Avatar
I don't know what the difference could be. Temperatures for sure, but why the disparity? Battery quality?
Old 01-26-16, 07:25 AM
Mike728
Mike728's Avatar
Yeah, checked the seat extender right after it was a posted issue.
One thing is, I drove it a little over 13k miles the first year. Never sat more than a day and no issue, obviously. Now, after almost three years, I have 15.5k. My job moved to the city and I started taking the train. The issue first appeared after sitting about two weeks. Jumped it and drove around all day. Happened again about a week later. Saw the threads on here regarding the issue on the ES and GS and bought a tender. If I forget to plug in in, it may not start within a week. Sometimes it does, sometimes it doesn't. I'm planning on getting the yearly oil change in a few weeks. I'll bring it up with them when I go. I guess I have nothing to lose.
Old 01-26-16, 10:09 AM
Maikerusan
Maikerusan's Avatar
Actually, just remembered. Car set for 3 weeks in cool temps while I was out of the country.
Started as always.
There is no way on earth a modern car should not start after sitting for a week. Something is wrong there.
Old 01-26-16, 10:39 AM
Universe93
Universe93's Avatar
Anyone know the specification of the stock battery? cold cranking amps and reserve capacity mainly?
Old 01-26-16, 10:40 AM
isfdude
isfdude's Avatar
Both of my Lexus cars battery's will die if not started in a month.
Old 02-21-16, 03:31 PM
Ronegone1
Ronegone1's Avatar
I just phased this issue yesterday when i got in my car to go out yesterday the car did not turn on. The relays began actin erratic and i thought it might be a dead battery. I needed to go out since i had a scheduled event so used a different car when i got back home about 4 hours later went to check what may be wrong with the car, the battery voltage with the car not turned on was at 6V VC (dead) gave the car a quick jump and started up. Let the battery charge for about 15 minutes or so which is not really much turned of the car and went to bed note this is about 3am in the morning. Through the research i read i thought this issue may be cause by the key being in close proximity of the car and constantly communicating with the the car's keyless system so i left the key before i went to bed more than 25 feet away from the car to see if it might affect my battery the following day when i try to start the car. Next morning about 11am i attempted to turn the car on, no problems what so ever note i barely charged the battery earlier that morning.
I think this issue may be caused if the keys are in close proximity of the car, try having the keys a bit farther and see if this may resolve your issue.
Old 02-23-16, 01:33 PM
sderman
sderman's Avatar
Just an aside. I am sure that those who keep finding their batteries have discharged significantly recognize that conventional batteries have much short lifespans if they often undergo deep discharge/charge cycles. They are just not designed for this. I suggest that you consider batteries designed for deep discharge such as the Optima line. For the last 12 years I have been using the same Optima Yellow Top in my 99 Vette (with a Battery Tender.) It is a shame you have to do this (my 14 ES starts easily after 3 weeks of inactivity), but it is good insurance.
Quick Reply: Continuous or phantom battery drains on our cars?
