Color mismatch - Lexus Dealer
4th Gear
New to the forum so pardon me if this has been addressed in another thread. I have a new 2023 ES 350 F Sport Handling in Iridium silver paint.
After a bit of bad luck with a blown semi truck tire, I had to have the front and rear bumpers replaced and repainted. The color the dealer used does not match the original factory paint.
The front bumper was repainted several times and still does not match.
Has anyone encountered this issue?
You can see the bumper is darker.
Same with the rear.
Same with the rear.
I believe Iridium is a new color offering for the ES so you'll not likely find any owners that had body work already with that particular color. I saw a post in the RX forum where an ultra white RX repair was mismatched with a white pearl repair - completely different color. Perhaps that happened with yours. Silver is close but no cigar??
GDC (02-27-23)
4th Gear
That’s what I was thinking as well. But it’s close enough and the touch up paint, which is also iridium, is darker so guess it’s back to the dealer to see what else they can do. Thanks for your reply.
It is impossible to have a human painter perfectly match factory paint if just painting one piece, blending onto adjoining panels is the only answer to make it look acceptable.
GDC (02-27-23)
It is very hard and complicated to paint the bumpers.
Same with the rear.
Same with the rear.
the problem is if they don’t blend the paint it would show much more
But tbh from the factory it’s not 100 percent
cause plastics bumpers and what ever the fenders are would also be a difference a perfect match would be a car wrap or if your bumpers were metal..
I have mett. Moonbeam beigh and it’s also alittle darker bumpers than the fenders and the car was brand new...
Go to a dealership or just looked at a parked car and your notice it in different at certain angles!!
GDC (02-27-23)
Iridium is a great looking color especially with the FSport black wheels. Good luck getting this resolved.
The following 2 users liked this post by mikemu30:
GDC (02-27-23),
GS350Miami (02-28-23)
Iridium is a great color. It looks very much like the previous Atomic Silver on our car. These pearl type paints are a multi-stage paint and I understand they are very difficult to match. It takes a very talented paint shop and your dealer just may not be up to the task. While I would have the most confidence in the dealer’s paint shop being able to match these unique paints, you may need to locate another experienced shop. Make sure to get references.
GDC (02-27-23)
Is it possible to order those pre painted from the factory?
Pre-painted works on small bits, mirror caps, etc. You wouldn't and couldn't do that on bumpers for a variety of reasons. you'd get a way worse match.
The match here looks fine. Of course it would need better photos in direct sun, but from what I see it's fine.
GDC (02-27-23)
Not to say this is the case with our cars, but it's also worth noting that most cars on the road, even brand new, the bumpers are a slight mismatch to the body paint. You wouldn't normally notice it but once you start looking, it's pretty apparent.
The following 2 users liked this post by F3Woody:
GDC (02-27-23),
