Turn the car on;
Turn the lights off;
Press on and hold te MENU button;
While holding the MENU button cycle the light ON/OFF switch 3 times (OFF PARKING LIGHTS ON - OFF PARKING LIGHTS ON - OFF PARKING LIGHTS ON;
Click on Function check settings;
Click on Camera settings;
Click on Steering angle settings;
Hold the MENU button until you see PAN OK, click on OK;
Then hold MENU button on MAX steering angle…
Turn the car on;
Done all of that, can’t get it to go beyond holding the MAX steering angle….. Nothing!
And I’m not paying Lexus for something that the Owner should be able to do. At least be part of the manual.
Try to hold the CLICK intead of MENU when MAX steering angle.
Also, keep in mind that you cannot reprogram it if your steering is not at zero angle/full max angle.
Maybe it’s better to straighten up the steering wheel and then to do zero point calibration.
Select Steering center memorize;
Straighten the steering wheel and click Steering center memorize;
Select Max steering steering angle memorize;
Turn left to the lock and click Max steering angle memorize;
Turn right to the lock and click Max steering angle memorize;
Straighten the steering wheel, click OK.
You will gear a beep and that means the new values are stored.
Anyone here knows how to re-calibrate the rear camera?
I can get to the 'Service Menu' however, it will not let me further set/save the 'Steering Center Memorize' or 'Max Steering Angle Memorize' options.
Your helpful knowledge is much appreciated.
I have a similar problem trying to do this. Once I get to the BACK CAMERA or STEERING ANGLE screen, I cannot select the STEERING ANGLE box - the mouse pointer seems to go away at that point and then I'm at a dead end. Any help would be appreciated.
