2019 es 350 f sport - tie rod end?
Hi,
Question to see if anyone else has had this repair. Currently in progress so still waiting on more info.
The dealer last week told me that the driver side tie rod end - outer - has "play" and needs to be replaced. Replacing this would also need alignment.
I went for a 2nd opinion as I only have 29k miles and have had the car since Nov 2019 so it seems early to me to be replacing this. My local mechanic who I trust said on 1st look he thinks it is the inner tie rod and would require replacing the steering rack. He is double checking this as that would be signficant.
Anyone else have a repair like this so early in the car's life?
It's possible. A tie rod end is supremely easy to detect/diagnose so I doubt they're yanking your chain. It's also incredibly cheap and incredibly easy part to replace. Such a repair is a non-issue. Have them fix it and go about your day. Should be under warranty. And to top it off you get a free alignment.
it's like $35. takes a couple of wrenches. get yourself a $100 alignment after. done.
https://www.ebay.com/itm/39440884274...3ABFBMivaJwv9h
Looks like the 2019 warranty was 4 years, unfortunately. So OP is either just inside or just outside the warranty. If he bought the car NEW in November 2019, he should still be covered and shouldn't agree to pay.
That's right - power train six years so he likely timed out on the years. Too bad. But failure of that in only 29K miles? Must have been damaged along the way.
thank you!
The following 3 users liked this post by BHL:
A good shop will offer to have the mechanic demonstrate to you when a ball joint / tie rod / bushing is bad. They’ll have you stand under the car and watch them jiggle it to show you it’s loose and worn/broken.
Seems unlikely the rack is bad at this low mileage, but maybe you hit a bad bump or pothole sideways?
Suspension work on a car like this is pretty sinple and any shop can handle the work. I’d look for a second opinion if dealership is putting a big repair quote your way. Edit: I just saw you had two opinions already
