NuLux Upholstery Auestion
Since I got my 2021 350 ES 2 years ago, little white dots have filled a scattering of the perforations in the passenger seat (
see photo). I’ve carefully pushed them back into where they belong with paper clip end. No harm done. No problem but why is this continually happening? Car used gently and carefully. 11,000 miles in 2.5 years. Anyone else talk to a dealership about this in their car?
BBQapple (07-22-23)
You're dealing with ventilated seats which pull air through those holes in the seating surface. The amount will depend upon your climate control settings for the ventilated seats.
Air has suspended particles (even the best clean rooms' air), people are continuously shedding stuff, and many types of clothing collect and/or shed lint of various sizes - all of that particulate material drifts along with the air being sucked toward and through the ventilated seat's ventilation holes. Some of or a combination of particulate material doesn't make it through the ventilation holes and accumulates into the white looking dots you're seeing.
ESh' s solution of vacuuming them out is. in my opinion, the better means of disposing of the white matter in the seats' ventilation holes.
I get it. Understandable explanation. Tried car vac. White stuffings were too jammed to be suctioned out with a car vac, Better solution for mine were the careful paper clip maneuver. Popped all five of them back in. Feel better now that I understand. I knew cool air came out through the holes to cool us but I didn’t think air was sucked in through those little perforations as well.
Are you sure? Because it sure feels like it’s blowing out to me.
Then how does the ventilation air cool the occupant’s body if it doesn’t come out of the holes and onto him? Also, if someone’s sitting on the perforations while the system is in operation, doesn’t that block the process just as the napkin does?
I’ll watch the You Tube video, too.
I find them to be far more effective than the ones that were in my TLX, which I believed used a push system vs a pull system in the Lexus.
I can't vouch for the accuracy, but here is an artificial intelligence response:The 2023 Lexus ES ventilated seats use a suction-style ventilation system. This means that air is pulled through the seat, rather than pushed out. The air is pulled through small vents in the seat bottom and backrest, and is then drawn out through larger vents in the seat cushion. This creates a flow of air that helps to cool the body and wick away moisture.
The suction-style ventilation system is more effective at cooling than a blower-style system because it does not require the air to be piped through the seat padding. This can help to prevent the seat from feeling too cool or drafty.
